标题: b540确定是好的bios [打印本页]
作者: 阳龙    时间: 2017-5-20 10:29
提示: 作者被禁止或删除 内容自动屏蔽
作者: ┋流年ヘ似水    时间: 2017-5-20 14:15
东西呢?怎么没有东西
作者: 阳龙    时间: 2017-5-20 16:48
提示: 作者被禁止或删除 内容自动屏蔽
作者: 班舵    时间: 2017-5-21 15:44
这个很强大了 回复                                  [attach]01481108[/attach][attach]01481109[/attach][attach]01481110[/attach][attach]01481111[/attach][attach]01481112[/attach][attach]01481113[/attach][attach]01481114[/attach][attach]01481115[/attach][attach]01481116[/attach][attach]01481117[/attach][attach]01481118[/attach][attach]01481119[/attach][attach]01481120[/attach][attach]01481121[/attach][attach]01481122[/attach][attach]01481123[/attach][attach]01481124[/attach][attach]01481125[/attach][attach]01481126[/attach][attach]01481127[/attach][attach]01481128[/attach][attach]01481129[/attach][attach]01481130[/attach][attach]01481131[/attach][attach]01481132[/attach][attach]01481133[/attach][attach]01481134[/attach][attach]01481135[/attach][attach]01481136[/attach][attach]01481137[/attach][attach]01481138[/attach][attach]01481139[/attach][attach]01481140[/attach][attach]01481141[/attach][attach]01481142[/attach][attach]01481143[/attach][attach]01481144[/attach][attach]01481145[/attach][attach]01481146[/attach][attach]01481147[/attach]
作者: 杜雨飞    时间: 2017-5-22 22:11
正需要这样的东西                                   [attach]01500417[/attach][attach]01500418[/attach][attach]01500419[/attach][attach]01500420[/attach][attach]01500421[/attach][attach]01500422[/attach][attach]01500423[/attach][attach]01500424[/attach][attach]01500425[/attach][attach]01500426[/attach][attach]01500427[/attach][attach]01500428[/attach][attach]01500429[/attach][attach]01500430[/attach][attach]01500431[/attach][attach]01500432[/attach][attach]01500433[/attach][attach]01500434[/attach][attach]01500435[/attach][attach]01500436[/attach][attach]01500437[/attach][attach]01500438[/attach][attach]01500439[/attach][attach]01500440[/attach][attach]01500441[/attach][attach]01500442[/attach][attach]01500443[/attach][attach]01500444[/attach][attach]01500445[/attach][attach]01500446[/attach][attach]01500447[/attach][attach]01500448[/attach][attach]01500449[/attach][attach]01500450[/attach][attach]01500451[/attach][attach]01500452[/attach][attach]01500453[/attach][attach]01500454[/attach][attach]01500455[/attach][attach]01500456[/attach]
作者: JANAN2013    时间: 2017-5-27 10:35
今天接到一台B540一体机,版号CIH77S V1.0 独显。开机无任何反应,测量各电感电压正常,屏幕不显示,下载楼主的BIOS刷后瞬间亮机,非常感谢!
作者: lgf8188    时间: 2017-6-8 12:27
好的吗!!我也需要个
作者: 小白看电脑    时间: 2017-6-9 13:06
带TV板的吗?????????
作者: 小白看电脑    时间: 2017-6-9 13:08
我的是带TV板的
作者: 阳龙    时间: 2017-6-9 13:40
提示: 作者被禁止或删除 内容自动屏蔽
作者: 阳龙    时间: 2017-6-9 13:41
提示: 作者被禁止或删除 内容自动屏蔽
作者: liujingchuan    时间: 2017-6-13 23:08
太*脏话*坑了  下了好多都是不能用   原来显示10秒现在倒好直接整不显示了     话说BU2是8MB还是2MB
作者: IT精锐    时间: 2017-6-19 15:16
这个是8还是4显,带不带TV 的?
作者: 软硬件通吃    时间: 2017-8-12 16:48
我接到这个没有TV板的好用吗,先下载试试!!!!
作者: 滕红林在线    时间: 2017-8-27 16:32
我下了几个了。都不行呀,试一下你的
作者: lxrq    时间: 2017-11-26 15:49
下载下来试试,看看能不能正常使用
作者: 嘉联维修    时间: 2018-1-27 14:55
这个文件大小不对,多了1KB,解压后应该是8192,他这个解压了是8193
作者: anko    时间: 2018-2-2 15:19
正需要这样的东西 !!!!!!
作者: 158185506    时间: 2018-11-24 17:49
电阻换了也不行,只有试试BIOS 了,偶尔正常使用,偶尔开机不显示,奇怪的问题
作者: 乌鸡    时间: 2021-6-18 19:14
这个很强大了
作者: MSI    时间: 2022-7-2 18:02
此BIOS比原机BIOS 容量大了一点   直接刷没问题  亲测
作者: xkflc2012    时间: 2025-4-2 12:52
阳龙 发表于 2017-5-20 16:48
**** 作者被禁止或删除 内容自动屏蔽 ****
确实是好用的,实测验证了,赞一个。
