标题: g40-45集显 amd [打印本页]
作者: 鬼鬼0735    时间: 2017-5-5 12:47
标题: g40-45集显 amd
客户机器修好备份的额
g40-45 集显amd.zip
2.37 MB, 下载次数: 38, 下载积分: 下载分 -2 分, 下载 1 次
放心 下载 版号nma281
作者: hl190    时间: 2017-5-7 10:33
楼主确定能用吧
作者: 蹲墙角的狗    时间: 2017-5-7 13:12
学习一下,正想了解呢                               [attach]01373386[/attach][attach]01373387[/attach][attach]01373388[/attach][attach]01373389[/attach][attach]01373390[/attach][attach]01373391[/attach][attach]01373392[/attach][attach]01373393[/attach][attach]01373394[/attach][attach]01373395[/attach][attach]01373396[/attach][attach]01373397[/attach][attach]01373398[/attach][attach]01373399[/attach][attach]01373400[/attach][attach]01373401[/attach][attach]01373402[/attach][attach]01373403[/attach][attach]01373405[/attach][attach]01373407[/attach]
作者: BoyhoodEMP    时间: 2017-5-7 19:43
真是好东西!                                       [attach]01382082[/attach][attach]01382083[/attach][attach]01382084[/attach][attach]01382085[/attach][attach]01382086[/attach][attach]01382087[/attach][attach]01382088[/attach][attach]01382089[/attach][attach]01382090[/attach][attach]01382091[/attach][attach]01382092[/attach][attach]01382093[/attach][attach]01382094[/attach][attach]01382095[/attach][attach]01382096[/attach][attach]01382097[/attach][attach]01382098[/attach][attach]01382099[/attach][attach]01382100[/attach][attach]01382101[/attach][attach]01382102[/attach][attach]01382103[/attach][attach]01382104[/attach][attach]01382105[/attach][attach]01382106[/attach][attach]01382107[/attach][attach]01382108[/attach][attach]01382109[/attach][attach]01382110[/attach][attach]01382111[/attach][attach]01382112[/attach][attach]01382113[/attach][attach]01382114[/attach][attach]01382115[/attach][attach]01382116[/attach][attach]01382117[/attach][attach]01382118[/attach][attach]01382119[/attach][attach]01382120[/attach][attach]01382121[/attach]
作者: hanson2002    时间: 2017-5-12 20:35
看看什么情况。还没遇到过                           [attach]01430577[/attach][attach]01430579[/attach][attach]01430581[/attach][attach]01430582[/attach][attach]01430583[/attach][attach]01430584[/attach][attach]01430585[/attach][attach]01430586[/attach][attach]01430587[/attach][attach]01430588[/attach][attach]01430589[/attach][attach]01430590[/attach][attach]01430591[/attach][attach]01430592[/attach][attach]01430593[/attach][attach]01430594[/attach][attach]01430595[/attach][attach]01430596[/attach][attach]01430597[/attach][attach]01430598[/attach][attach]01430599[/attach][attach]01430600[/attach][attach]01430601[/attach][attach]01430602[/attach][attach]01430603[/attach][attach]01430604[/attach][attach]01430605[/attach][attach]01430606[/attach][attach]01430607[/attach][attach]01430608[/attach][attach]01430609[/attach][attach]01430610[/attach][attach]01430611[/attach][attach]01430612[/attach][attach]01430613[/attach][attach]01430614[/attach][attach]01430615[/attach][attach]01430616[/attach][attach]01430617[/attach][attach]01430618[/attach]
作者: hzjs    时间: 2017-5-15 13:04
感谢楼主分享了。                                   [attach]01448354[/attach][attach]01448355[/attach][attach]01448356[/attach][attach]01448357[/attach][attach]01448358[/attach][attach]01448359[/attach][attach]01448360[/attach][attach]01448361[/attach][attach]01448362[/attach][attach]01448363[/attach][attach]01448364[/attach][attach]01448365[/attach][attach]01448366[/attach][attach]01448367[/attach][attach]01448368[/attach][attach]01448369[/attach][attach]01448370[/attach][attach]01448371[/attach][attach]01448372[/attach][attach]01448373[/attach][attach]01448374[/attach][attach]01448375[/attach][attach]01448376[/attach][attach]01448377[/attach][attach]01448378[/attach][attach]01448379[/attach][attach]01448380[/attach][attach]01448381[/attach][attach]01448382[/attach][attach]01448383[/attach][attach]01448384[/attach][attach]01448385[/attach][attach]01448386[/attach][attach]01448387[/attach][attach]01448388[/attach][attach]01448389[/attach][attach]01448390[/attach][attach]01448391[/attach][attach]01448392[/attach][attach]01448393[/attach]
作者: yucheng1102    时间: 2017-5-16 14:33
真是万能的吗?瞧瞧                                 [attach]01460013[/attach][attach]01460014[/attach][attach]01460015[/attach][attach]01460016[/attach][attach]01460017[/attach][attach]01460018[/attach][attach]01460019[/attach][attach]01460020[/attach][attach]01460021[/attach][attach]01460022[/attach][attach]01460023[/attach][attach]01460024[/attach][attach]01460025[/attach][attach]01460026[/attach][attach]01460027[/attach][attach]01460028[/attach][attach]01460029[/attach][attach]01460030[/attach][attach]01460031[/attach][attach]01460032[/attach][attach]01460033[/attach][attach]01460034[/attach][attach]01460035[/attach][attach]01460036[/attach][attach]01460037[/attach][attach]01460038[/attach][attach]01460039[/attach][attach]01460040[/attach][attach]01460041[/attach][attach]01460042[/attach][attach]01460043[/attach][attach]01460044[/attach][attach]01460045[/attach][attach]01460046[/attach][attach]01460047[/attach][attach]01460048[/attach][attach]01460049[/attach][attach]01460050[/attach][attach]01460051[/attach][attach]01460052[/attach]
作者: lxb199    时间: 2017-6-12 15:19
这个BIOS是好的,我测了OK
作者: jxh275723151    时间: 2017-6-17 13:51
版号nma281
这个BIOS是好的,我测了OK
作者: jxh275723151    时间: 2017-6-17 14:08
这个BIOS是好的,我测了OK
作者: jxh275723151    时间: 2017-6-17 14:10
这个BIOS是好的,我测了OK
作者: oyc264    时间: 2018-5-29 17:52
我上机试过是可以的。电流也是差不多的。但有显示,原为是0.45A
