Thinkpa T430 开机都都都都报警不显示
ong桥
2017-5-4 14:42
内存报警,刷4M的就OK了,
T430 U99.zip
(2.32 MB, 下载次数: 146)
2017-5-4 14:42 上传
点击文件名下载附件
kufish520
2017-5-10 18:57
先收藏下,以备下次使用! [attach]01412334[/attach][attach]01412335[/attach][attach]01412336[/attach][attach]01412337[/attach][attach]01412338[/attach][attach]01412339[/attach][attach]01412340[/attach][attach]01412341[/attach][attach]01412342[/attach][attach]01412343[/attach][attach]01412344[/attach][attach]01412345[/attach][attach]01412346[/attach][attach]01412347[/attach][attach]01412348[/attach][attach]01412349[/attach][attach]01412350[/attach][attach]01412351[/attach][attach]01412353[/attach][attach]01412355[/attach]
在乡村
2017-5-14 19:43
感谢分享学习了 [attach]01442784[/attach][attach]01442785[/attach][attach]01442786[/attach][attach]01442787[/attach][attach]01442788[/attach][attach]01442789[/attach][attach]01442790[/attach][attach]01442791[/attach][attach]01442792[/attach][attach]01442793[/attach][attach]01442794[/attach][attach]01442795[/attach][attach]01442796[/attach][attach]01442797[/attach][attach]01442798[/attach][attach]01442799[/attach][attach]01442800[/attach][attach]01442801[/attach][attach]01442802[/attach][attach]01442803[/attach]
雨中等待
2017-5-14 21:57
路过 看看。。。。。。。。。。。。 [attach]01447652[/attach][attach]01447653[/attach][attach]01447654[/attach][attach]01447655[/attach][attach]01447656[/attach][attach]01447657[/attach][attach]01447658[/attach][attach]01447659[/attach][attach]01447660[/attach][attach]01447661[/attach][attach]01447662[/attach][attach]01447663[/attach][attach]01447664[/attach][attach]01447665[/attach][attach]01447666[/attach][attach]01447667[/attach][attach]01447668[/attach][attach]01447669[/attach][attach]01447670[/attach][attach]01447671[/attach]
ong桥
2017-5-15 12:32
雨中等待 发表于 2017-5-14 21:57
路过 看看。。。。。。。。。。。。
赚分吧,,,,,,,
漂落的梦
2017-6-9 17:55
我刷了 还是一样报警呢
7247247241
2017-6-10 14:20
下来试试,希望可以用
lb1982a
2017-11-22 21:38
正好碰到 下来试试
孟州老张
2021-1-25 10:20
u99是4m的bios
u49是8mbios
