休假一个月,归来第一天小修华硕x502开机0.5a掉电!!!!!
谯鹏
2017-5-1 08:53
拿到机子就是一个裸板了,开机上0.5a掉电。测各大电感就是cpu附近有一组电没有出,集成显卡的主板 。怀疑集显供电不出。上坛子找找到个点位,急忙打开。查看证明了先前的判断 这种情况首先就是刷bios 论坛bios还比较少 抱着试试的态度下了一个 一般不行我就上马云家买 老式的编程器慢呀!!!8m的文件刷大概3分钟 装上开机过0.5A 不掉 估计亮机了 装机ok bios坛子有就不再发了
李强超
2017-5-1 09:13
楼主好思路,不出集显bios多
jmmairongzhang
2017-5-1 09:47
楼主放完长假一点也不生,技术扎实
szsps
2017-5-2 22:38
只是来看看 [attach]01330335[/attach][attach]01330336[/attach][attach]01330337[/attach][attach]01330338[/attach][attach]01330339[/attach][attach]01330340[/attach][attach]01330341[/attach][attach]01330342[/attach][attach]01330343[/attach][attach]01330344[/attach][attach]01330345[/attach][attach]01330346[/attach][attach]01330347[/attach][attach]01330348[/attach][attach]01330349[/attach][attach]01330350[/attach][attach]01330351[/attach][attach]01330352[/attach][attach]01330353[/attach][attach]01330354[/attach]
飘雪青松
2017-5-4 15:48
好,路过,学习了.... [attach]01346784[/attach][attach]01346785[/attach][attach]01346786[/attach][attach]01346787[/attach][attach]01346788[/attach][attach]01346789[/attach][attach]01346790[/attach][attach]01346791[/attach][attach]01346792[/attach][attach]01346793[/attach][attach]01346794[/attach][attach]01346795[/attach][attach]01346796[/attach][attach]01346797[/attach][attach]01346798[/attach][attach]01346799[/attach][attach]01346800[/attach][attach]01346801[/attach][attach]01346802[/attach][attach]01346803[/attach]
cai7689
2017-5-5 16:32
好东西买回来配货 [attach]01358572[/attach][attach]01358573[/attach][attach]01358574[/attach][attach]01358575[/attach][attach]01358576[/attach][attach]01358577[/attach][attach]01358578[/attach][attach]01358579[/attach][attach]01358580[/attach][attach]01358581[/attach][attach]01358582[/attach][attach]01358583[/attach][attach]01358584[/attach][attach]01358585[/attach][attach]01358586[/attach][attach]01358587[/attach][attach]01358588[/attach][attach]01358589[/attach][attach]01358590[/attach][attach]01358591[/attach][attach]01358592[/attach][attach]01358593[/attach][attach]01358594[/attach][attach]01358595[/attach][attach]01358596[/attach][attach]01358597[/attach][attach]01358598[/attach][attach]01358599[/attach][attach]01358600[/attach][attach]01358601[/attach][attach]01358602[/attach][attach]01358603[/attach][attach]01358604[/attach][attach]01358605[/attach][attach]01358606[/attach][attach]01358607[/attach][attach]01358608[/attach][attach]01358609[/attach][attach]01358610[/attach][attach]01358611[/attach]
bingh0090
2017-5-7 18:34
支持一下,多谢分享 [attach]01380816[/attach][attach]01380817[/attach][attach]01380818[/attach][attach]01380819[/attach][attach]01380820[/attach][attach]01380821[/attach][attach]01380822[/attach][attach]01380823[/attach][attach]01380824[/attach][attach]01380825[/attach][attach]01380826[/attach][attach]01380827[/attach][attach]01380828[/attach][attach]01380829[/attach][attach]01380830[/attach][attach]01380831[/attach][attach]01380832[/attach][attach]01380833[/attach][attach]01380834[/attach][attach]01380835[/attach][attach]01380836[/attach][attach]01380837[/attach][attach]01380838[/attach][attach]01380839[/attach][attach]01380840[/attach][attach]01380841[/attach][attach]01380842[/attach][attach]01380843[/attach][attach]01380844[/attach][attach]01380845[/attach][attach]01380846[/attach][attach]01380847[/attach][attach]01380848[/attach][attach]01380849[/attach][attach]01380850[/attach][attach]01380851[/attach][attach]01380852[/attach][attach]01380853[/attach][attach]01380854[/attach][attach]01380855[/attach]
hanson2002
2017-5-7 18:40
谢谢太有用了 [attach]01380962[/attach][attach]01380963[/attach][attach]01380964[/attach][attach]01380965[/attach][attach]01380966[/attach][attach]01380967[/attach][attach]01380968[/attach][attach]01380969[/attach][attach]01380970[/attach][attach]01380971[/attach][attach]01380972[/attach][attach]01380973[/attach][attach]01380974[/attach][attach]01380975[/attach][attach]01380976[/attach][attach]01380977[/attach][attach]01380978[/attach][attach]01380979[/attach][attach]01380980[/attach][attach]01380981[/attach][attach]01380982[/attach][attach]01380983[/attach][attach]01380984[/attach][attach]01380985[/attach][attach]01380986[/attach][attach]01380987[/attach][attach]01380988[/attach][attach]01380989[/attach][attach]01380990[/attach][attach]01380991[/attach][attach]01380992[/attach][attach]01380993[/attach][attach]01380994[/attach][attach]01380995[/attach][attach]01380996[/attach][attach]01380997[/attach][attach]01380998[/attach][attach]01380999[/attach][attach]01381000[/attach][attach]01381001[/attach]
cyh11540
2017-5-8 13:56
希望这个可以解决问题 [attach]01387775[/attach][attach]01387776[/attach][attach]01387777[/attach][attach]01387778[/attach][attach]01387779[/attach][attach]01387780[/attach][attach]01387781[/attach][attach]01387782[/attach][attach]01387783[/attach][attach]01387784[/attach][attach]01387785[/attach][attach]01387786[/attach][attach]01387787[/attach][attach]01387788[/attach][attach]01387789[/attach][attach]01387790[/attach][attach]01387791[/attach][attach]01387792[/attach][attach]01387793[/attach][attach]01387794[/attach][attach]01387795[/attach][attach]01387796[/attach][attach]01387797[/attach][attach]01387798[/attach][attach]01387799[/attach][attach]01387800[/attach][attach]01387801[/attach][attach]01387802[/attach][attach]01387803[/attach][attach]01387804[/attach][attach]01387805[/attach][attach]01387806[/attach][attach]01387807[/attach][attach]01387808[/attach][attach]01387809[/attach][attach]01387810[/attach][attach]01387811[/attach][attach]01387812[/attach][attach]01387813[/attach][attach]01387814[/attach]
zzxiucai
2017-5-8 14:04
支持分享顶一下 [attach]01389026[/attach][attach]01389027[/attach][attach]01389028[/attach][attach]01389029[/attach][attach]01389030[/attach][attach]01389031[/attach][attach]01389032[/attach][attach]01389033[/attach][attach]01389034[/attach][attach]01389035[/attach][attach]01389036[/attach][attach]01389037[/attach][attach]01389038[/attach][attach]01389039[/attach][attach]01389040[/attach][attach]01389041[/attach][attach]01389042[/attach][attach]01389043[/attach][attach]01389044[/attach][attach]01389045[/attach][attach]01389046[/attach][attach]01389047[/attach][attach]01389048[/attach][attach]01389049[/attach][attach]01389050[/attach][attach]01389051[/attach][attach]01389052[/attach][attach]01389053[/attach][attach]01389054[/attach][attach]01389055[/attach][attach]01389056[/attach][attach]01389057[/attach][attach]01389058[/attach][attach]01389059[/attach][attach]01389060[/attach][attach]01389061[/attach][attach]01389062[/attach][attach]01389063[/attach][attach]01389064[/attach][attach]01389065[/attach]
林白
2017-5-10 23:13
支持下吧,都不容易啊 [attach]01414911[/attach][attach]01414912[/attach][attach]01414913[/attach][attach]01414914[/attach][attach]01414915[/attach][attach]01414916[/attach][attach]01414917[/attach][attach]01414918[/attach][attach]01414919[/attach][attach]01414920[/attach][attach]01414921[/attach][attach]01414922[/attach][attach]01414923[/attach][attach]01414924[/attach][attach]01414925[/attach][attach]01414926[/attach][attach]01414927[/attach][attach]01414928[/attach][attach]01414929[/attach][attach]01414930[/attach]
bingh0090
2017-5-10 23:13
真是辛苦了、感谢您的分享、 [attach]01414931[/attach][attach]01414932[/attach][attach]01414933[/attach][attach]01414934[/attach][attach]01414935[/attach][attach]01414936[/attach][attach]01414937[/attach][attach]01414938[/attach][attach]01414939[/attach][attach]01414940[/attach][attach]01414941[/attach][attach]01414942[/attach][attach]01414943[/attach][attach]01414944[/attach][attach]01414945[/attach][attach]01414946[/attach][attach]01414947[/attach][attach]01414948[/attach][attach]01414949[/attach][attach]01414950[/attach][attach]01414951[/attach][attach]01414952[/attach][attach]01414953[/attach][attach]01414954[/attach][attach]01414955[/attach][attach]01414956[/attach][attach]01414957[/attach][attach]01414958[/attach][attach]01414959[/attach][attach]01414960[/attach][attach]01414961[/attach][attach]01414962[/attach][attach]01414963[/attach][attach]01414964[/attach][attach]01414965[/attach][attach]01414966[/attach][attach]01414967[/attach][attach]01414968[/attach][attach]01414969[/attach][attach]01414970[/attach]
sbg007
2017-5-11 13:04
好东西先收藏了 [attach]01419079[/attach][attach]01419080[/attach][attach]01419081[/attach][attach]01419082[/attach][attach]01419083[/attach][attach]01419084[/attach][attach]01419085[/attach][attach]01419086[/attach][attach]01419087[/attach][attach]01419088[/attach][attach]01419089[/attach][attach]01419090[/attach][attach]01419091[/attach][attach]01419092[/attach][attach]01419093[/attach][attach]01419094[/attach][attach]01419095[/attach][attach]01419096[/attach][attach]01419097[/attach][attach]01419098[/attach][attach]01419099[/attach][attach]01419100[/attach][attach]01419101[/attach][attach]01419102[/attach][attach]01419103[/attach][attach]01419104[/attach][attach]01419105[/attach][attach]01419106[/attach][attach]01419107[/attach][attach]01419108[/attach][attach]01419109[/attach][attach]01419110[/attach][attach]01419111[/attach][attach]01419112[/attach][attach]01419113[/attach][attach]01419114[/attach][attach]01419115[/attach][attach]01419116[/attach][attach]01419117[/attach][attach]01419118[/attach]
