标题: 求联想 S400 独显 BIOS 版号VIUS3/VIUS4 LA-8951P REV:1.0 [打印本页]
作者: assnpl    时间: 2017-4-28 17:36
求联想 S400 独显 BIOS  版号VIUS3/VIUS4  LA-8951P REV:1.0  I5 CPU 确定能用的
论坛上下了七八个多不是,刷了不显示 电流到0.9
机子原来问题是不显示,电流到0.9
作者: assnpl    时间: 2017-4-28 22:29
各位大师傅们,这个型号好的BIOS多没有吗????
作者: waifer    时间: 2017-4-30 22:09
谢谢了。刚学新手,正好有用。                       [attach]01309872[/attach][attach]01309873[/attach][attach]01309874[/attach][attach]01309875[/attach][attach]01309876[/attach][attach]01309877[/attach][attach]01309878[/attach][attach]01309879[/attach][attach]01309880[/attach][attach]01309881[/attach][attach]01309882[/attach][attach]01309883[/attach][attach]01309884[/attach][attach]01309885[/attach][attach]01309886[/attach][attach]01309887[/attach][attach]01309888[/attach][attach]01309889[/attach][attach]01309890[/attach][attach]01309891[/attach]
作者: icbczhq    时间: 2017-5-2 16:52
学习一下,下次有问题就能解决了                     [attach]01327001[/attach][attach]01327002[/attach][attach]01327003[/attach][attach]01327004[/attach][attach]01327005[/attach][attach]01327006[/attach][attach]01327007[/attach][attach]01327008[/attach][attach]01327009[/attach][attach]01327010[/attach][attach]01327011[/attach][attach]01327012[/attach][attach]01327013[/attach][attach]01327014[/attach][attach]01327015[/attach][attach]01327016[/attach][attach]01327017[/attach][attach]01327018[/attach][attach]01327019[/attach][attach]01327020[/attach][attach]01327021[/attach][attach]01327022[/attach][attach]01327023[/attach][attach]01327024[/attach][attach]01327025[/attach][attach]01327026[/attach][attach]01327027[/attach][attach]01327028[/attach][attach]01327029[/attach][attach]01327030[/attach][attach]01327031[/attach][attach]01327032[/attach][attach]01327033[/attach][attach]01327034[/attach][attach]01327035[/attach][attach]01327036[/attach][attach]01327037[/attach][attach]01327038[/attach][attach]01327039[/attach][attach]01327040[/attach]
作者: siva1233    时间: 2017-5-4 18:55
好东西,楼主辛苦了a                                [attach]01350515[/attach][attach]01350516[/attach][attach]01350517[/attach][attach]01350518[/attach][attach]01350519[/attach][attach]01350520[/attach][attach]01350521[/attach][attach]01350522[/attach][attach]01350523[/attach][attach]01350524[/attach][attach]01350525[/attach][attach]01350526[/attach][attach]01350527[/attach][attach]01350528[/attach][attach]01350529[/attach][attach]01350530[/attach][attach]01350531[/attach][attach]01350532[/attach][attach]01350533[/attach][attach]01350534[/attach][attach]01350535[/attach][attach]01350536[/attach][attach]01350537[/attach][attach]01350538[/attach][attach]01350539[/attach][attach]01350540[/attach][attach]01350541[/attach][attach]01350542[/attach][attach]01350543[/attach][attach]01350544[/attach][attach]01350545[/attach][attach]01350546[/attach][attach]01350547[/attach][attach]01350548[/attach][attach]01350549[/attach][attach]01350550[/attach][attach]01350551[/attach][attach]01350552[/attach][attach]01350553[/attach][attach]01350554[/attach]
作者: kaka580    时间: 2017-5-5 17:30
好东西必须顶谢谢                                   [attach]01359955[/attach][attach]01359956[/attach][attach]01359957[/attach][attach]01359958[/attach][attach]01359959[/attach][attach]01359960[/attach][attach]01359961[/attach][attach]01359962[/attach][attach]01359963[/attach][attach]01359964[/attach][attach]01359965[/attach][attach]01359966[/attach][attach]01359967[/attach][attach]01359968[/attach][attach]01359969[/attach][attach]01359970[/attach][attach]01359971[/attach][attach]01359972[/attach][attach]01359973[/attach][attach]01359974[/attach][attach]01359975[/attach][attach]01359976[/attach][attach]01359977[/attach][attach]01359978[/attach][attach]01359979[/attach][attach]01359980[/attach][attach]01359981[/attach][attach]01359982[/attach][attach]01359983[/attach][attach]01359984[/attach][attach]01359985[/attach][attach]01359986[/attach][attach]01359987[/attach][attach]01359988[/attach][attach]01359989[/attach][attach]01359990[/attach][attach]01359991[/attach][attach]01359992[/attach][attach]01359993[/attach][attach]01359994[/attach]
作者: 到了时间    时间: 2017-5-8 16:59
谢谢分享啊                                         [attach]01391760[/attach][attach]01391761[/attach][attach]01391762[/attach][attach]01391763[/attach][attach]01391764[/attach][attach]01391765[/attach][attach]01391766[/attach][attach]01391767[/attach][attach]01391768[/attach][attach]01391769[/attach][attach]01391770[/attach][attach]01391771[/attach][attach]01391772[/attach][attach]01391773[/attach][attach]01391774[/attach][attach]01391775[/attach][attach]01391776[/attach][attach]01391777[/attach][attach]01391778[/attach][attach]01391779[/attach]
作者: sunqinghai12    时间: 2017-5-8 19:15
这技术得赞一个                                     [attach]01393179[/attach][attach]01393180[/attach][attach]01393181[/attach][attach]01393182[/attach][attach]01393183[/attach][attach]01393184[/attach][attach]01393185[/attach][attach]01393186[/attach][attach]01393187[/attach][attach]01393188[/attach][attach]01393189[/attach][attach]01393190[/attach][attach]01393191[/attach][attach]01393192[/attach][attach]01393193[/attach][attach]01393194[/attach][attach]01393195[/attach][attach]01393196[/attach][attach]01393197[/attach][attach]01393198[/attach]
作者: bin9420    时间: 2017-5-9 13:22
学习一下 楼主辛苦了                                [attach]01395658[/attach][attach]01395659[/attach][attach]01395660[/attach][attach]01395661[/attach][attach]01395662[/attach][attach]01395663[/attach][attach]01395664[/attach][attach]01395665[/attach][attach]01395666[/attach][attach]01395667[/attach][attach]01395668[/attach][attach]01395669[/attach][attach]01395670[/attach][attach]01395671[/attach][attach]01395672[/attach][attach]01395673[/attach][attach]01395674[/attach][attach]01395675[/attach][attach]01395676[/attach][attach]01395677[/attach][attach]01395678[/attach][attach]01395679[/attach][attach]01395680[/attach][attach]01395681[/attach][attach]01395682[/attach][attach]01395683[/attach][attach]01395684[/attach][attach]01395685[/attach][attach]01395686[/attach][attach]01395687[/attach][attach]01395688[/attach][attach]01395689[/attach][attach]01395690[/attach][attach]01395691[/attach][attach]01395692[/attach][attach]01395693[/attach][attach]01395694[/attach][attach]01395695[/attach][attach]01395696[/attach][attach]01395697[/attach]
作者: iagufm    时间: 2017-5-9 16:34
谢谢楼主分享,学习了                               [attach]01400324[/attach][attach]01400325[/attach][attach]01400326[/attach][attach]01400327[/attach][attach]01400328[/attach][attach]01400329[/attach][attach]01400330[/attach][attach]01400331[/attach][attach]01400332[/attach][attach]01400333[/attach][attach]01400334[/attach][attach]01400335[/attach][attach]01400336[/attach][attach]01400337[/attach][attach]01400338[/attach][attach]01400339[/attach][attach]01400340[/attach][attach]01400341[/attach][attach]01400342[/attach][attach]01400343[/attach][attach]01400344[/attach][attach]01400345[/attach][attach]01400346[/attach][attach]01400347[/attach][attach]01400348[/attach][attach]01400349[/attach][attach]01400350[/attach][attach]01400351[/attach][attach]01400352[/attach][attach]01400353[/attach][attach]01400354[/attach][attach]01400355[/attach][attach]01400356[/attach][attach]01400357[/attach][attach]01400358[/attach][attach]01400359[/attach][attach]01400360[/attach][attach]01400361[/attach][attach]01400362[/attach][attach]01400363[/attach]
作者: aijinshen    时间: 2017-5-9 18:01
正需要这款通用电源模块。                           [attach]01402369[/attach][attach]01402370[/attach][attach]01402371[/attach][attach]01402372[/attach][attach]01402373[/attach][attach]01402374[/attach][attach]01402375[/attach][attach]01402376[/attach][attach]01402377[/attach][attach]01402378[/attach][attach]01402379[/attach][attach]01402380[/attach][attach]01402381[/attach][attach]01402382[/attach][attach]01402383[/attach][attach]01402384[/attach][attach]01402385[/attach][attach]01402386[/attach][attach]01402387[/attach][attach]01402388[/attach][attach]01402389[/attach][attach]01402390[/attach][attach]01402391[/attach][attach]01402392[/attach][attach]01402393[/attach][attach]01402394[/attach][attach]01402395[/attach][attach]01402396[/attach][attach]01402397[/attach][attach]01402398[/attach][attach]01402399[/attach][attach]01402400[/attach][attach]01402401[/attach][attach]01402402[/attach][attach]01402403[/attach][attach]01402404[/attach][attach]01402405[/attach][attach]01402406[/attach][attach]01402407[/attach][attach]01402408[/attach]
作者: zzxiucai    时间: 2017-5-9 19:07
谢谢楼主分享的经验                                 [attach]01403951[/attach][attach]01403952[/attach][attach]01403953[/attach][attach]01403954[/attach][attach]01403955[/attach][attach]01403956[/attach][attach]01403957[/attach][attach]01403958[/attach][attach]01403959[/attach][attach]01403960[/attach][attach]01403961[/attach][attach]01403962[/attach][attach]01403963[/attach][attach]01403964[/attach][attach]01403965[/attach][attach]01403966[/attach][attach]01403967[/attach][attach]01403968[/attach][attach]01403969[/attach][attach]01403970[/attach][attach]01403971[/attach][attach]01403972[/attach][attach]01403973[/attach][attach]01403974[/attach][attach]01403975[/attach][attach]01403976[/attach][attach]01403977[/attach][attach]01403978[/attach][attach]01403979[/attach][attach]01403980[/attach][attach]01403981[/attach][attach]01403982[/attach][attach]01403983[/attach][attach]01403984[/attach][attach]01403985[/attach][attach]01403986[/attach][attach]01403987[/attach][attach]01403988[/attach][attach]01403989[/attach][attach]01403990[/attach]
作者: mfkdhtyv    时间: 2017-5-21 12:52
我也在找这个BIOS,谁有测试过能用的BIOS没有,发一个
作者: wo13480nk    时间: 2017-6-30 20:53
我的也是到0.9左右不显示,你的好了么
作者: wmj0318    时间: 2017-7-27 11:36
觉得不是bios,这个有可能是显卡坏咯
作者: zouxibo    时间: 2017-11-20 17:18
waifer 发表于 2017-4-30 22:09
谢谢了。刚学新手,正好有用。
这是神回复呀 呵呵
作者: 马立东    时间: 2018-7-21 12:38
我的也是到0.9不亮
作者: 硬盒红塔山    时间: 2019-3-19 19:08
找到BIOS了么,我也有个机器这样了,
作者: 汇通    时间: 2021-1-18 10:42
  15秒亮机有点慢  可以点亮
