标题: DELL N4110 [打印本页]
作者: 广灵子    时间: 2017-4-20 16:59
标题: DELL N4110
DELL N4110 待机有3.3V 没有5v,这个是正常的,机器不触发,开关有3.3跳变,可以刷一下ECbios,管好!
N4110 EC.zip
57.64 KB, 下载次数: 50, 下载积分: 下载分 -2 分, 下载 1 次
作者: arjon    时间: 2017-4-22 21:40
谢谢了,先下载收藏                                 [attach]01276436[/attach][attach]01276437[/attach][attach]01276438[/attach][attach]01276439[/attach][attach]01276440[/attach][attach]01276441[/attach][attach]01276442[/attach][attach]01276443[/attach][attach]01276444[/attach][attach]01276445[/attach][attach]01276446[/attach][attach]01276447[/attach][attach]01276448[/attach][attach]01276449[/attach][attach]01276450[/attach][attach]01276451[/attach][attach]01276452[/attach][attach]01276453[/attach][attach]01276454[/attach][attach]01276455[/attach]
作者: 谁人无过    时间: 2017-4-24 20:00
谢谢楼主分享资料。。。                             [attach]01283904[/attach][attach]01283905[/attach][attach]01283906[/attach][attach]01283907[/attach][attach]01283908[/attach][attach]01283909[/attach][attach]01283910[/attach][attach]01283911[/attach][attach]01283912[/attach][attach]01283913[/attach][attach]01283914[/attach][attach]01283915[/attach][attach]01283916[/attach][attach]01283917[/attach][attach]01283918[/attach][attach]01283919[/attach][attach]01283920[/attach][attach]01283921[/attach][attach]01283922[/attach][attach]01283923[/attach]
作者: 永恒飞扬    时间: 2017-4-25 16:12
正需要呢!!!找了好久哦                           [attach]01286393[/attach][attach]01286394[/attach][attach]01286395[/attach][attach]01286396[/attach][attach]01286397[/attach][attach]01286398[/attach][attach]01286399[/attach][attach]01286400[/attach][attach]01286401[/attach][attach]01286402[/attach][attach]01286403[/attach][attach]01286404[/attach][attach]01286405[/attach][attach]01286406[/attach][attach]01286407[/attach][attach]01286408[/attach][attach]01286409[/attach][attach]01286410[/attach][attach]01286411[/attach][attach]01286412[/attach]
作者: 难得正经    时间: 2017-4-26 19:50
手里有一个不触发的,试试                           [attach]01291399[/attach][attach]01291400[/attach][attach]01291401[/attach][attach]01291402[/attach][attach]01291403[/attach][attach]01291404[/attach][attach]01291405[/attach][attach]01291406[/attach][attach]01291407[/attach][attach]01291408[/attach][attach]01291409[/attach][attach]01291410[/attach][attach]01291411[/attach][attach]01291412[/attach][attach]01291413[/attach][attach]01291414[/attach][attach]01291415[/attach][attach]01291416[/attach][attach]01291417[/attach][attach]01291418[/attach]
作者: 奥格数码    时间: 2017-4-26 21:22
撸主厉害!学习了                                   [attach]01293123[/attach][attach]01293124[/attach][attach]01293125[/attach][attach]01293126[/attach][attach]01293127[/attach][attach]01293128[/attach][attach]01293129[/attach][attach]01293130[/attach][attach]01293131[/attach][attach]01293132[/attach][attach]01293133[/attach][attach]01293134[/attach][attach]01293135[/attach][attach]01293136[/attach][attach]01293137[/attach][attach]01293138[/attach][attach]01293139[/attach][attach]01293140[/attach][attach]01293141[/attach][attach]01293142[/attach]
作者: cgh888cgh888    时间: 2017-4-28 11:19
楼主好思路,正需要
作者: tg888    时间: 2017-5-1 16:01
感谢楼主分享哈哈                                   [attach]01318856[/attach][attach]01318857[/attach][attach]01318858[/attach][attach]01318859[/attach][attach]01318860[/attach][attach]01318861[/attach][attach]01318862[/attach][attach]01318863[/attach][attach]01318864[/attach][attach]01318865[/attach][attach]01318866[/attach][attach]01318867[/attach][attach]01318868[/attach][attach]01318869[/attach][attach]01318870[/attach][attach]01318871[/attach][attach]01318872[/attach][attach]01318873[/attach][attach]01318874[/attach][attach]01318875[/attach][attach]01318876[/attach][attach]01318877[/attach][attach]01318878[/attach][attach]01318879[/attach][attach]01318880[/attach][attach]01318881[/attach][attach]01318882[/attach][attach]01318883[/attach][attach]01318884[/attach][attach]01318885[/attach][attach]01318886[/attach][attach]01318887[/attach][attach]01318888[/attach][attach]01318889[/attach][attach]01318890[/attach][attach]01318891[/attach][attach]01318892[/attach][attach]01318893[/attach][attach]01318894[/attach][attach]01318895[/attach]
作者: 因特办公    时间: 2017-5-5 12:47
这个很有用                                         [attach]01353436[/attach][attach]01353437[/attach][attach]01353438[/attach][attach]01353439[/attach][attach]01353440[/attach][attach]01353441[/attach][attach]01353442[/attach][attach]01353443[/attach][attach]01353444[/attach][attach]01353445[/attach][attach]01353446[/attach][attach]01353448[/attach][attach]01353449[/attach][attach]01353450[/attach][attach]01353451[/attach][attach]01353452[/attach][attach]01353453[/attach][attach]01353454[/attach][attach]01353455[/attach][attach]01353456[/attach]
作者: chen1128    时间: 2019-2-23 11:37
反馈   刷后正常使用。。。。。。
