标题: G50-75M 板号:NM-A291 工厂BIOS绝对好用 [打印本页]
作者: liuhaiyong    时间: 2017-4-17 09:45
作者: liuhaiyong    时间: 2017-4-17 09:49
不好意思,刚刚没传上
NM-A291.rar
2.21 MB, 下载次数: 3628, 下载积分: 下载分 -2 分, 下载 1 次
作者: zhaozhzh    时间: 2017-4-17 10:11
不错。下载下来收藏备用。
作者: 鹏城翼豹    时间: 2017-4-22 11:19
谢谢奉献,我刚要用上                               [attach]01273860[/attach][attach]01273861[/attach][attach]01273863[/attach][attach]01273864[/attach][attach]01273865[/attach][attach]01273866[/attach][attach]01273867[/attach][attach]01273868[/attach][attach]01273869[/attach][attach]01273870[/attach][attach]01273871[/attach][attach]01273872[/attach][attach]01273873[/attach][attach]01273874[/attach][attach]01273875[/attach][attach]01273876[/attach][attach]01273877[/attach][attach]01273878[/attach][attach]01273879[/attach][attach]01273880[/attach]
作者: shixu1982091    时间: 2017-4-24 12:37
感谢无私奉献                                       [attach]01282469[/attach][attach]01282470[/attach][attach]01282471[/attach][attach]01282472[/attach][attach]01282473[/attach][attach]01282474[/attach][attach]01282475[/attach][attach]01282476[/attach][attach]01282477[/attach][attach]01282478[/attach][attach]01282479[/attach][attach]01282480[/attach][attach]01282481[/attach][attach]01282482[/attach][attach]01282483[/attach][attach]01282484[/attach][attach]01282485[/attach][attach]01282486[/attach][attach]01282487[/attach][attach]01282488[/attach]
作者: 大地农民    时间: 2017-4-25 17:59
好东西,正好需要                                   [attach]01287129[/attach][attach]01287130[/attach][attach]01287131[/attach][attach]01287132[/attach][attach]01287133[/attach][attach]01287134[/attach][attach]01287135[/attach][attach]01287136[/attach][attach]01287137[/attach][attach]01287138[/attach][attach]01287139[/attach][attach]01287140[/attach][attach]01287141[/attach][attach]01287142[/attach][attach]01287143[/attach][attach]01287144[/attach][attach]01287145[/attach][attach]01287146[/attach][attach]01287147[/attach][attach]01287148[/attach]
作者: 海洋飞雪    时间: 2017-4-26 20:52
正需要这款通用电源模块。                           [attach]01292557[/attach][attach]01292558[/attach][attach]01292559[/attach][attach]01292560[/attach][attach]01292561[/attach][attach]01292562[/attach][attach]01292563[/attach][attach]01292564[/attach][attach]01292565[/attach][attach]01292566[/attach][attach]01292567[/attach][attach]01292568[/attach][attach]01292569[/attach][attach]01292570[/attach][attach]01292571[/attach][attach]01292572[/attach][attach]01292573[/attach][attach]01292574[/attach][attach]01292575[/attach][attach]01292576[/attach]
作者: 天佑电脑    时间: 2017-4-29 17:36
谢谢分享谢谢                                       [attach]01302953[/attach][attach]01302954[/attach][attach]01302955[/attach][attach]01302956[/attach][attach]01302957[/attach][attach]01302958[/attach][attach]01302959[/attach][attach]01302960[/attach][attach]01302961[/attach][attach]01302962[/attach][attach]01302963[/attach][attach]01302964[/attach][attach]01302965[/attach][attach]01302966[/attach][attach]01302967[/attach][attach]01302968[/attach][attach]01302969[/attach][attach]01302970[/attach][attach]01302971[/attach][attach]01302972[/attach]
作者: 北极老熊    时间: 2017-5-21 18:34
有验证过吗,下来试试,
作者: zhengqqaia99    时间: 2017-5-30 11:29
显卡驱动打不上,刷个BIOS不知道行不行
作者: 醉卧烟云    时间: 2017-6-1 14:11
下载试试,希望好用
作者: 醉卧烟云    时间: 2017-6-1 18:47
好用,感谢楼主分享
作者: 747757228    时间: 2017-6-2 14:38
谢谢分享
作者: 747757228    时间: 2017-6-2 14:40
今天碰到进系统很卡很慢刷一个试试
作者: 7247247241    时间: 2017-6-2 18:13
谢谢奉献,我刚要用上
作者: 你那都不是事    时间: 2017-6-3 14:12
大家试了吗?  可以用吗
作者: lianerqiqi    时间: 2017-6-3 14:51
刷上了好用
作者: niwotaxiaowang    时间: 2017-6-4 14:05
是好的么 下载试试
作者: niwotaxiaowang    时间: 2017-6-4 14:07
有人试过的??、
作者: xujiaguo88    时间: 2017-6-7 09:44
独立还是集成
作者: 老婆在哪里    时间: 2017-6-7 10:17
涮上去试试  多谢楼主
作者: wwn486    时间: 2017-6-7 10:26
收下留存,哈哈哈
作者: mjh0755    时间: 2017-6-10 14:07
好像刷了独显用不了,不知道是不是我的显卡问题
作者: scl1364    时间: 2017-7-15 11:23
好东西,感谢分享,一刷就OK了。。。
作者: zhujw    时间: 2017-7-24 12:35
刚下好.机子竟然又可以了.发贴怎么要30个字符呢
作者: 金华联想    时间: 2017-7-29 17:58
加电0.6-0.9跳变2下 就掉电。掉电后还可触发。刷了BIOS 一样。供电量了都有了。会是显卡问题吗
作者: 星仔本本    时间: 2017-7-31 19:12
下了   可能我机子不是bios问题吧
作者: LAOYUANYUAN    时间: 2017-8-26 11:16
刷上以后进不了系统了,u盘也启动不了。刷之前是可以的
作者: 陈建东    时间: 2017-9-8 11:06
是A10 的CPU吗,我的是A10的CPU,不知道能用不?
作者: 天阳科技    时间: 2017-10-3 16:58
正好需要。感谢楼主分享。下载刷看。
作者: yaoli1256    时间: 2017-10-19 17:52
感谢 刚好遇到一个一样的机器 感谢 刚好遇到一个一样的机器 感谢 刚好遇到一个一样的机器 感谢 刚好遇到一个一样的机器
作者: 双剑合璧    时间: 2017-11-1 21:33
我正在修Z40-75 不知道能不能用 看版号两个一样的 下载试试  刷可以了会回帖 不行不回  哈哈哈
作者: 双剑合璧    时间: 2017-11-1 22:52
经过验证可以与Z40-75机子通用的
作者: qiang321    时间: 2017-12-4 07:51
手边有台这机器,有时候正常,有时候暗屏,先刷个BIOS试试
作者: 恒信笔记本维修    时间: 2017-12-28 16:30
我的开机不显示 下载了还是不行 是不是CPU 坏啦
作者: leyvi    时间: 2018-1-31 14:44
好用
作者: 495937628    时间: 2018-3-28 16:24
谢谢,找了半天终于找到了。。。。。。。。。。。。。。。。。。。。
作者: 一介孤镖2011    时间: 2018-4-4 11:42
触发电流到0.84不动,刷了BIOS涛声依旧。要换板了估计。
作者: 阿禧    时间: 2018-4-26 10:18
感谢楼主的无私奉献,我下载下来试一试
作者: 我锋我有型    时间: 2018-6-29 11:39
刚好在修这个机器,先下一个备用
作者: 鹰飞长空    时间: 2018-7-1 11:01
刷好后,开机正常显示
作者: 云涛科技    时间: 2018-7-16 16:31
下载试试,希望好用................................
作者: mofe    时间: 2018-8-18 15:10
好用,顶一个。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。。
作者: zz470321412    时间: 2018-11-11 13:27
独显  没问题 ok 亲测
作者: hnsmx    时间: 2018-12-10 11:25
独立的,已验证,好用,放心下载
作者: jiandan8663    时间: 2018-12-30 11:46
我以为下载量那么高的是好的 ..结果我 下了刷了不能用... 论坛里又下了个刷上好了
作者: liuguangsong    时间: 2019-1-21 17:51
我是独立显卡 刷完就好了,前面加复的字少也能发表,我的怎么提示字少那
作者: 喜欢晒太阳    时间: 2019-1-21 18:05
谢谢分享 不错哦 技术很好 顶顶 学习了
作者: LUZHENGYI    时间: 2019-2-19 11:18
wifi   报错的  不知道是不是  型号不一样
作者: 低凋、进行曲    时间: 2019-3-6 14:41
休眠唤不醒               重启死机
作者: 王胜军    时间: 2019-5-17 15:38
谢谢                 BIOS是好的
作者: 天天快乐之一    时间: 2019-6-7 16:31
谢谢分享,支持楼主。
作者: 天天快乐之一    时间: 2019-6-7 16:33
终于找到了,谢谢分享。
作者: 天上飘的云    时间: 2019-10-19 14:49
一样WiFi报错  是不一样吧
作者: 延超笔记本维修    时间: 2019-12-29 15:37
我想要这个BIOS 谢谢
作者: hry177    时间: 2020-3-8 16:48
下载试一试
作者: lyw1976dl    时间: 2020-3-28 11:49
好用,感谢分享!
作者: 1696543855    时间: 2020-4-1 10:33
开机不显示灰屏  刷了直接秒亮机
作者: 心静思远    时间: 2020-5-1 22:24
有没有人用过,能不能显,你们光是灌水的啊
作者: 心静思远    时间: 2020-5-2 21:40
经过下载试了,点亮机器是没有问题的,但是提示无线网卡末经授权什么的,无法开机,拆掉网卡进系统重新更新BIOS才搞定
作者: 赵文平123    时间: 2020-9-29 16:54
刷完无线网卡报错
作者: FYSM888    时间: 2021-4-6 14:33
下来试试看
作者: 280801256    时间: 2021-4-14 15:49
Lenovo V1070 板号一样 ,刷完不进系统, logo比例不对, 此BIOS对应15寸机器 ,
作者: walkman0626    时间: 2021-7-4 20:26
下下下,好好好
作者: walkman0626    时间: 2021-7-4 20:47
分不分集成和独立啊?
作者: eijo2015    时间: 2022-4-9 17:44
G50-75刷完网卡报错,PE进去蓝盘,插硬盘挡机。本来是BIOS有密码 没别的问题
作者: !狼行千里    时间: 2022-4-9 18:00
感谢无私奉献
作者: 110977127    时间: 2022-5-2 12:02
好用 ,谢谢谢谢
作者: chxd23    时间: 2022-10-19 08:35
刚好修到这款机器,有电源开不机 有电池可以开机
作者: qq16921602    时间: 2023-2-14 16:03
刷完后能开机,但是进PE蓝屏.还的拆开重刷
作者: VXyVTdia    时间: 2023-2-20 18:40
感谢 非常感谢
作者: 杰辉电脑维修    时间: 2023-3-9 10:06
下载试试好用再来回复
作者: 丁福友    时间: 2023-4-11 13:15
我的加电不亮刷上试试看
作者: alfa0908    时间: 2023-8-3 19:52
谢谢 分享 我刚准备要 正好
作者: 邓州维科    时间: 2023-9-19 19:13
刷上无线网卡报错进不去系统    去掉网线 可以进系统
作者: 惠联网络    时间: 2024-6-29 20:45
刷完开机报未经授权的无线网卡
