标题: 神舟 K660D-i7 D2 修改过BIOS [打印本页]
作者: 一修就坏    时间: 2017-4-15 15:11
神舟 K660D-i7 D2 修改过 BIOS 板号_DAOTWKMB8C0 REV_C   N16P-GX-A2独显
神舟 K660D-i7 D2 修改过 板号_DAOTWKMB8C0 REV_C N16P-GX-A2独显.zip
3.31 MB, 阅读权限: 50, 下载次数: 317, 下载积分: 下载分 -2 分, 下载 1 次
售价: 2 分下载分  [记录]
作者: 蓝天8848    时间: 2017-4-15 23:46
我的型号是K660E-I7 D7, 板号DAOTWKMB8C0 REV_C, 显卡N16P-GX-A2   独显驱动装不上。
作者: 13932063854    时间: 2017-4-16 16:27
显卡模块不对
作者: xitg    时间: 2017-4-21 13:12
感谢楼主,又学到一招咯                             [attach]01270898[/attach][attach]01270899[/attach][attach]01270900[/attach][attach]01270901[/attach][attach]01270902[/attach][attach]01270903[/attach][attach]01270904[/attach][attach]01270905[/attach][attach]01270906[/attach][attach]01270907[/attach][attach]01270908[/attach][attach]01270909[/attach][attach]01270910[/attach][attach]01270911[/attach][attach]01270912[/attach][attach]01270913[/attach][attach]01270914[/attach][attach]01270915[/attach][attach]01270916[/attach][attach]01270917[/attach]
作者: 明天的明明    时间: 2017-4-21 14:47
自己改的ME吗、
作者: windowsxp    时间: 2017-4-24 12:42
正好需要谢谢                                       [attach]01283289[/attach][attach]01283290[/attach][attach]01283291[/attach][attach]01283292[/attach][attach]01283293[/attach][attach]01283294[/attach][attach]01283295[/attach][attach]01283296[/attach][attach]01283297[/attach][attach]01283298[/attach][attach]01283299[/attach][attach]01283300[/attach][attach]01283301[/attach][attach]01283302[/attach][attach]01283303[/attach][attach]01283304[/attach][attach]01283305[/attach][attach]01283306[/attach][attach]01283307[/attach][attach]01283308[/attach]
作者: hongyejiang    时间: 2017-4-24 19:51
正在准备下载中                                     [attach]01283782[/attach][attach]01283783[/attach][attach]01283784[/attach][attach]01283785[/attach][attach]01283786[/attach][attach]01283787[/attach][attach]01283788[/attach][attach]01283789[/attach][attach]01283790[/attach][attach]01283791[/attach][attach]01283792[/attach][attach]01283793[/attach][attach]01283794[/attach][attach]01283795[/attach][attach]01283796[/attach][attach]01283797[/attach][attach]01283798[/attach][attach]01283799[/attach][attach]01283800[/attach][attach]01283801[/attach]
作者: 利威维修    时间: 2017-4-27 16:16
下载下来,试试我的内存反复自检
作者: 英俊的小峰哥    时间: 2017-4-28 21:17
支持楼主,。。。。                                 [attach]01301139[/attach][attach]01301140[/attach][attach]01301141[/attach][attach]01301142[/attach][attach]01301143[/attach][attach]01301144[/attach][attach]01301145[/attach][attach]01301146[/attach][attach]01301147[/attach][attach]01301148[/attach][attach]01301149[/attach][attach]01301150[/attach][attach]01301151[/attach][attach]01301152[/attach][attach]01301153[/attach][attach]01301154[/attach][attach]01301155[/attach][attach]01301156[/attach][attach]01301157[/attach][attach]01301158[/attach]
作者: 张志雄    时间: 2017-5-4 18:17
为什么下载不了?
作者: xxe    时间: 2017-5-8 14:55
我的不亮机,刷楼主bios可以亮机。不知道怎么回事现在用一个小时会关机
作者: 小机警    时间: 2017-6-15 15:15
我试试看,我这个是开机不亮
作者: freesky123    时间: 2017-6-17 12:34
我的半个小时准断电  刷了这个也是没有ME 一会测试回来再回帖
作者: lurui    时间: 2017-11-9 18:48
好了吗   我有个30分钟断电11111111111111
作者: lieyan890828    时间: 2017-11-9 19:01
我的也是 大家都试了吗 好了吗 尽快回复
作者: ¥烙铁头¥    时间: 2017-12-15 19:13
我的是不过显卡 下来试试   是双bios的吧   不知道有没有刷成功的
作者: 万佳国度    时间: 2018-2-26 16:09
楼主的标题有误啊,看到修改二字,大多数人以为是修改了ME的,其实楼主的是修改了开机LOGO的,变成了DELL外星人的LOGO了。
不过其他一切正常,测试没问题,我的是D2版本
作者: askdsk    时间: 2018-6-20 14:29
k660d-i7  d1 的刷了    用半小时掉电了
作者: 1063102527    时间: 2018-9-5 15:08
这个BIOS  亲测 可以用 显卡也没问题 显卡GTX 860M 的
作者: 1063102527    时间: 2018-9-5 16:06
我的也是半小时断电   非常准  正好半个小时
作者: AOS    时间: 2019-7-25 17:50
刷了BIOS 之后可以正常亮机, 不过准时30分钟掉电,每次值得一样,太神奇了
作者: 阿勇88    时间: 2021-4-21 22:44
我刷了也是半小时掉电!
作者: 227000633    时间: 2021-11-28 01:27
试试看,正好需要
作者: Jyt0852    时间: 2022-4-23 22:46
怎么下载不了
作者: lichao6306353    时间: 2024-5-26 17:23
测试过了  半小时掉电
