标题: U36SD reV 2.1 OKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK [打印本页]
作者: prmengku1    时间: 2017-4-13 23:38
U36SD reV 2.1  OKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK
TEST
BACKUP ORI APHE NYALA NORMAL i7.rar
1.57 MB, 下载次数: 144, 下载积分: 下载分 -2 分, 下载 1 次
作者: xlhong    时间: 2017-4-25 18:49
谢谢,十分感谢了                                   [attach]01287621[/attach][attach]01287622[/attach][attach]01287623[/attach][attach]01287624[/attach][attach]01287625[/attach][attach]01287626[/attach][attach]01287627[/attach][attach]01287628[/attach][attach]01287629[/attach][attach]01287630[/attach][attach]01287631[/attach][attach]01287632[/attach][attach]01287633[/attach][attach]01287634[/attach][attach]01287635[/attach][attach]01287636[/attach][attach]01287637[/attach][attach]01287638[/attach][attach]01287639[/attach][attach]01287640[/attach]
作者: sinoor    时间: 2017-4-26 18:58
之前用过,现在看看                                 [attach]01290361[/attach][attach]01290362[/attach][attach]01290363[/attach][attach]01290364[/attach][attach]01290365[/attach][attach]01290366[/attach][attach]01290367[/attach][attach]01290368[/attach][attach]01290369[/attach][attach]01290370[/attach][attach]01290371[/attach][attach]01290372[/attach][attach]01290373[/attach][attach]01290374[/attach][attach]01290375[/attach][attach]01290376[/attach][attach]01290377[/attach][attach]01290378[/attach][attach]01290379[/attach][attach]01290380[/attach]
作者: 11123456    时间: 2017-10-2 14:50
bios没问题                                                      。。
作者: 122816541    时间: 2018-3-18 17:04
机器之前开机 电流上到0.9左右的样子  点不亮  BIOS刷上 果断亮机    感谢楼主  感谢大迅维
作者: a842028812    时间: 2021-12-29 14:17
bios开机慢
作者: 龙少恒良    时间: 2022-2-24 16:42
谢谢楼主分享。触发0.9无显示 ,刷刷就好了
作者: 秦奋    时间: 2022-8-8 13:46
刷了,打不上显卡驱动
