标题: ACER LA-C611P OK 工厂BIOS SR23Y CPU可用 [打印本页]
作者: xxbbllll    时间: 2017-4-11 16:42
ACER LA-C611P OK 工厂BIOS SR23Y CPU可用,其它CPU待验证
ACER LA-C611P OK.zip
4.33 MB, 下载次数: 1657, 下载积分: 下载分 -2 分, 下载 1 次
售价: 5 分下载分  [记录]
作者: zb26nt    时间: 2017-4-19 20:06
谢谢楼主分享!!!                                 [attach]01265284[/attach][attach]01265285[/attach][attach]01265286[/attach][attach]01265287[/attach][attach]01265288[/attach][attach]01265289[/attach][attach]01265290[/attach][attach]01265291[/attach][attach]01265292[/attach][attach]01265293[/attach][attach]01265294[/attach][attach]01265295[/attach][attach]01265296[/attach][attach]01265297[/attach][attach]01265298[/attach][attach]01265299[/attach][attach]01265300[/attach][attach]01265301[/attach][attach]01265302[/attach]
作者: ltpcc    时间: 2017-4-20 19:23
进来看看,学习下                                   [attach]01268307[/attach][attach]01268308[/attach][attach]01268309[/attach][attach]01268310[/attach][attach]01268311[/attach][attach]01268312[/attach][attach]01268313[/attach][attach]01268314[/attach][attach]01268315[/attach][attach]01268316[/attach][attach]01268317[/attach][attach]01268318[/attach][attach]01268319[/attach][attach]01268320[/attach][attach]01268321[/attach][attach]01268322[/attach][attach]01268323[/attach][attach]01268324[/attach][attach]01268325[/attach][attach]01268326[/attach]
作者: xxbbllll    时间: 2017-4-21 13:33
zb26nt 发表于 2017-4-19 20:06
谢谢楼主分享!!!
有没有好,这个机子有5代CPU和6代CPU之分,所以如果是6代CPU应该用不了
作者: zerioce    时间: 2017-4-21 14:06
我下了,谢谢无私奉献                               [attach]01271290[/attach][attach]01271291[/attach][attach]01271292[/attach][attach]01271293[/attach][attach]01271294[/attach][attach]01271295[/attach][attach]01271296[/attach][attach]01271297[/attach][attach]01271298[/attach][attach]01271299[/attach][attach]01271300[/attach][attach]01271301[/attach][attach]01271302[/attach][attach]01271303[/attach][attach]01271304[/attach][attach]01271305[/attach][attach]01271306[/attach][attach]01271307[/attach][attach]01271308[/attach][attach]01271309[/attach]
作者: yl0002002    时间: 2017-4-22 11:46
感谢分享,希望多有一点这样的帖子                   [attach]01274045[/attach][attach]01274046[/attach][attach]01274047[/attach][attach]01274048[/attach][attach]01274049[/attach][attach]01274050[/attach][attach]01274051[/attach][attach]01274052[/attach][attach]01274053[/attach][attach]01274054[/attach][attach]01274055[/attach][attach]01274056[/attach][attach]01274057[/attach][attach]01274058[/attach][attach]01274059[/attach][attach]01274060[/attach][attach]01274061[/attach][attach]01274062[/attach][attach]01274063[/attach][attach]01274064[/attach]
作者: 欲林军    时间: 2017-4-24 12:29
谢谢了,先下载收藏                                 [attach]01281027[/attach][attach]01281028[/attach][attach]01281029[/attach][attach]01281030[/attach][attach]01281031[/attach][attach]01281032[/attach][attach]01281033[/attach][attach]01281034[/attach][attach]01281035[/attach][attach]01281036[/attach][attach]01281037[/attach][attach]01281038[/attach][attach]01281039[/attach][attach]01281040[/attach][attach]01281041[/attach][attach]01281042[/attach][attach]01281043[/attach][attach]01281044[/attach][attach]01281045[/attach][attach]01281046[/attach]
作者: make88    时间: 2017-4-24 20:30
不知道好坏啊,有确认好的吗
作者: xxbbllll    时间: 2017-4-25 14:56
make88 发表于 2017-4-24 20:30
不知道好坏啊,有确认好的吗
只要你是这个CPU就肯定可以用
作者: 老婆在哪里    时间: 2017-4-25 15:23
先收藏 多谢楼主
作者: cooloio    时间: 2017-4-25 16:09
感谢楼主的分享精神                                 [attach]01286370[/attach][attach]01286371[/attach][attach]01286372[/attach][attach]01286373[/attach][attach]01286374[/attach][attach]01286375[/attach][attach]01286376[/attach][attach]01286377[/attach][attach]01286378[/attach][attach]01286379[/attach][attach]01286380[/attach][attach]01286381[/attach][attach]01286382[/attach][attach]01286383[/attach][attach]01286384[/attach][attach]01286385[/attach][attach]01286386[/attach][attach]01286387[/attach][attach]01286388[/attach][attach]01286389[/attach]
作者: llhsxy    时间: 2017-4-27 10:04
谢谢楼主分享。下载试试
作者: hjx593    时间: 2017-6-2 14:31
SR2EY ?是楼主写错还是本来就有这个U?
作者: 7247247241    时间: 2017-6-2 18:01
我的是不触发 是不是bios的问题
作者: 11466116    时间: 2017-6-4 14:06
我的是集成的
作者: 99435882    时间: 2017-6-6 10:12
已验证 可以开机是好的  谢谢 6带的CPU  6200我的
作者: wxjqqqqq    时间: 2017-6-11 15:05
谢谢楼主分享
作者: xuqianbei    时间: 2017-7-7 18:09
测试过了这BIOS是好的,我的CPU是SR2EY .................
作者: 雄风笔记本维修    时间: 2017-7-21 16:11
我的CPU是  SR2EY 可以用不
作者: 品味咖啡    时间: 2017-8-7 10:30
我现在遇到一台这个型号,开机电流0.08 几秒就掉下来,不知道是不是BOIS问题
作者: qw1824290389    时间: 2017-11-14 12:05
有没有人刷好过啊   出来表示一下
作者: zhuxiaojiang    时间: 2017-11-29 19:37
已测试SR2EY 6代U可亮机 其它无测
作者: 847902061    时间: 2018-5-28 08:32
我的也是6代i5 6200集显的 刷了不亮电流卡在0.18 别的bios 刷了可以亮 就是灰屏 闪屏 不知道是不是U的问题了
作者: 郑仲明    时间: 2018-12-18 12:56
BIOS测试OK 6代CPU
作者: 新乡华宇    时间: 2018-12-25 18:56
郑仲明 发表于 2018-12-18 12:56
BIOS测试OK 6代CPU
6代6200,。不行。掉电。。。。。。。。。。。。。 BIOS
作者: dgd871025    时间: 2019-12-5 14:37
下载试试吧
作者: 皮皮鳝    时间: 2020-11-10 13:50
经测试可用感谢
作者: 鼎好2011    时间: 2021-7-4 17:17
下载试试,开机掉电
作者: 鼎好2011    时间: 2021-7-4 17:24
有点位图的教程吗!!!新手
作者: jackey829    时间: 2023-10-16 13:37
我这个上电电充不跳变,下下来试一下,一会上传结果~~~~
作者: 1206942213    时间: 2024-7-30 18:12
SR2EY那应该是6代的PCU
作者: 1206942213    时间: 2024-7-30 18:13
搂主这是5代的处理器,楼下看有刷的 也是好的是6代的处理器
作者: VX5oSVJJ    时间: 2024-11-9 15:13
下来试试,如果可以定回复
作者: VX5oSVJJ    时间: 2024-11-13 13:16
我好像下载过似乎
