标题: dell inspiron 3521 not on [打印本页] 作者: balu457157 时间: 2017-4-6 16:43 标题: dell inspiron 3521 not on i changed 3v 5v ic same.. now board getting on but if i shutdown power indication two lights blinking continuously.. what should i change now.. i thougt its intel issue.. pls help me resolve作者: バ幸福De右岸 时间: 2017-4-7 07:19
你说的是啥意思看不懂啊?作者: Amy同学 时间: 2017-4-24 19:38
as far as Im concerned,i dont think the problem is 3.5v ic,maybe its the windows (system ),and the drive.u should start with the easy one redo a windows first ,then we do the ic part作者: Amy同学 时间: 2017-4-24 19:40
a lot of windows 10 has the same problem (blink lights)作者: バ幸福De右岸 时间: 2017-5-3 06:15
