希捷ST2000DL003 CC3C 错误代码分析
linkxin88
2017-3-30 23:52
Boot 0x40M
Spin Up[0x000246DF]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
RECOVERED Op=0900 Resp=0005
(P) SATA Reset
MediaPartition:
Host LBA Length Disc LBA Length Start Cyl Head
Media Partition 00000000 0099A9C0 00000000 00133538 00000000 00000000
MC 00000000 0098A148 00000000 00131429 00000000 00000000
MSP 00991F38 00000C98 001323E7 00000193 000001D0 00000005
User Partition 0099A9C0 00133538 000001C5 00000005
MCMainPOR: Start:
Check MCMT Version: Current
MCInitialize: Start: Buffer Words VBM: 00000210
ClearMC: Start Full Media Cache size in host blks 00989680..........
ClearMC: Completed, Last LBA 00989680
MC Area is re-initialized.
MCInitialize: MC Cleared
MCInitialize: MCTBufferPtr->Header.MCTStateFlags = 0000000A
MCInitialize: MCTBufferPtr->Header.MCStateFlagsDisc = 00000001
MCInitialize: MCStateFlags = 00000001
Set MCMT Version Current
[MCMTWS]
MC Seg Disc and Cache Nodes: 40134924 40132A34
Seg Write Preamble VBM start: 000011B2 end: 000011D9
Footer - start: 000011DB end: 00001202
Seg Read Preamble VBM - start: 00001204 end: 0000122B
Footer - start: 0000122D end: 00001254
MCInitialize: Init complete:
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = 00000041
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 00000022
MCMainPOR: MCStateFlags = 00000041
MCMainPOR: Feature Enabled...
MSP MainPOR:
MSP Init Metadata
Buf Bytes/VBM 00000210 DBA Base 40000000
Metadata size in bytes 0040
Num Segments 0064
Logical Sector Alignment 00000000
MSP Reconstruction
MSP Read ScratchPad Section 0000 DiscLBA 001323E7 BlkSize 00000C80 Num Segments 00000064 DiscLba 001323E7
No valid segments found
MSP MSP Main Store Verify Reconstruction Status 10003000
Reconstruction Status 00003000
MSP Init ScratchPad on DiscDiscLBA 001323E7 DiscSize 00000190 PhyBlkLBA 00991F38 BlkSize 00000C80
Write MSP Segment PhyBlkLBA 00991F38 BlkSize 00000C80 DiscLba 001323E7 RW_RTL FFFFFFFF
MSP MainPOR: Complete
MSP MainPOR: Feature Enabled...
ScratchPad restore NOT required
linkxin88
2017-3-30 23:53
F3 T>/TJ CAP: (P1=00) Validation Key: 00000020 (P1=01) HDA Serial Number: 5YD70KFY (P1=02) PCBA Serial Number: 0000M2143M7B (P1=03) PCBA Part Number: Invalid (P1=04) Head Count: 06 (P1=05) Node Name Validation Key: 01 (P1=06) Node Name: 50 00 C5 00 44 C8 D1 B7 (P1=07) Product Family ID: 4F (P1=08) Product Family ID: 02 (P1=09) PCBA Build Code: Invalid (P1=0A) ASIC Info: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 (P1=0B) Firmware Key: FF FF FF FF FF FF FF FF FF FF FF FF FF FF (P1=0C) Firmware Key Checksum: FFFF (P1=0D) Date of Manufacture: 11072011 (P1=0E) Destroked Buf Size Index: 03 (P1=0F) Final Mfg Op: Invalid (P1=10) Final Mfg Erc: Undefined (P1=11) System Area Prep State: FE (P1=12) SPT Auto Run Delay: 00 (P1=13) Reserved: 00 (P1=14) Checksum: FFFF (P1=15) External Model Number: ST2000DL003-9VT166 (P1=16) Internal Model Number: ST2000DL003-9VT166 (P1=17) IDEMA Capacity: E8E088B0 (P1=18) Reserved1: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
linkxin88
2017-3-30 23:54
二楼是硬盘信息
xinshili888
2017-3-31 00:06
很想帮你,实在无能为力
helloyf
2017-3-31 07:43
实在是看不懂。楼主你这个是用什么软件分析到的吗?
linkxin88
2017-3-31 20:46
(128.58 KB, 下载次数: 58)
下载附件
保存到相册
2017-3-31 20:45 上传
linkxin88
2017-3-31 20:52
F3 T>/TJ
CAP:
(P1=01) HDA Serial Number: 5YD728W0
(P1=02) PCBA Serial Number: 0000K201CYNT
(P1=06) Node Name: 50 00 C5 00 44 C3 1C 4E
(P1=0A) ASIC Info:
(P1=0D) Date of Manufacture: 11082011
(P1=18) Reserved1:
F3 T>/1N8
DERP
dec error DERP
Hours - LBA R Theta Z EC Cmd type retry temp count type
0 - 1D20CAA3 9 358D 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20CB62 9 4539 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20CC21 9 54E5 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20CCE0 9 6492 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20CD9F 9 7397 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20CE5E 9 8343 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20CF1D 9 92F0 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20CFDC 9 A29C 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D09B 9 B249 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D15A 9 C1F5 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D219 9 D1A1 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D2D8 9 E14E 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D397 9 F053 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D456 9 0 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D515 9 FAC 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D5D4 9 1F58 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D693 9 2F05 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D752 9 3EB1 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D811 9 4E5E 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D8D0 9 5E0A 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20D98F 9 6D0F 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20C9E4 9 25E0 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20DF87 9 E9CB 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E046 9 F978 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E105 9 924 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E1C6 9 18D0 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E283 9 287D 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E342 9 3829 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E401 9 47D6 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E4C0 9 5782 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E57F 9 6687 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E63E 9 7634 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E6FD 9 85E0 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20E7BC 9 958D 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20C925 9 1634 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20DA4E 9 7CBC 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20DB0D 9 8C68 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20DBCC 9 9C14 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20DC8B 9 ABC1 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20DD4A 9 BB6D 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20DE09 9 CB1A 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20DEC8 9 DAC6 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20DF87 9 E9CB 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E046 9 F978 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E105 9 924 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E1C4 9 18D0 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E284 9 287D 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E342 9 3829 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E401 9 47D6 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E4C0 9 5782 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E57F 9 6687 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E63E 9 7634 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E6FD 9 85E0 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E7BC 9 958D 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20CB63 9 4539 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20E283 9 287D 0 43110081 0 FF FF 10 1 BGMS dos rewrite
0 - 1D20CAA6 9 358D 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CB6A 9 45E0 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CC21 9 54E5 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CCE0 9 6492 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CD9F 9 7397 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CE5E 9 8343 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CF1D 9 92F0 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CFDC 9 A29C 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D09B 9 B249 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D15A 9 C1F5 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D21D 9 D1A1 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D2D8 9 E14E 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D397 9 F053 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D456 9 0 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D515 9 FAC 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D5D4 9 1F58 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D693 9 2F05 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D752 9 3EB1 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D811 9 4E5E 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D8D0 9 5E0A 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D990 9 6DB6 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20C9E4 9 25E0 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CAB6 9 36DB 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CC2C 9 558D 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CCE1 9 6492 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CDA1 9 743E 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D15D 9 C1F5 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D22D 9 D2F0 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D398 9 F0FA 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D697 9 2F05 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D753 9 3EB1 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D8D1 9 5E0A 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D21A 9 D1A1 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D2D9 9 E14E 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D698 9 2FAC 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D98F 9 6D0F 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20DA4E 9 7CBC 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20DB0D 9 8C68 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20DBCD 9 9C14 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20DC8B 9 ABC1 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20DD4A 9 BB6D 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20DE09 9 CB1A 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20DEC8 9 DAC6 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20C925 9 1634 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20C9ED 9 2687 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CAA5 9 358D 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CB76 9 4687 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20CC2A 9 558D 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20D694 9 2F05 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20DA4F 9 7CBC 0 43110081 0 FF FF 13 1 BGMS dos rewrite
0 - 1D20DBCC 9 9C14 0 43110081 0 FF FF 13 1 BGMS dos rewrite
F3 1>/TV2
System Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI
0 0 0 0 0 0 0 26B77 0 FFFFFFFF 0
3B41F B9E1 B9E1 0 1 0 1 2622C 0 FFFFFFFF 46E00
7683E B9E1 173C2 0 2 0 2 26E8C 0 FFFFFFFF 8DC00
B1C5D B9E1 22DA3 0 3 0 3 26C08 0 FFFFFFFF D4A00
ED07C B9E1 2E784 0 4 0 4 2931B 0 FFFFFFFF 11B800
12849B B9E1 3A165 0 5 0 5 28F44 0 FFFFFFFF 162600
1638BA B9E1 45B46 120 0 0 6 26C97 0 FFFFFFFF 1A9400
19ECD9 B9E1 51527 120 1 0 7 2634C 0 FFFFFFFF 1F0200
1DA0F8 B9E1 5CF08 120 2 0 8 26FAC 0 FFFFFFFF 237000
215517 B9E1 688E9 120 3 0 9 26D28 0 FFFFFFFF 27DE00
250936 B9E1 742CA 120 4 0 A 2943B 0 FFFFFFFF 2C4C00
28BD55 B9E1 7FCAB 120 5 0 B 29064 0 FFFFFFFF 30BA00
Head 0: entries 2 slips B9E1
Head 1: entries 2 slips 173C2
Head 2: entries 2 slips 173C2
Head 3: entries 2 slips 173C2
Head 4: entries 2 slips 173C2
Head 5: entries 2 slips 173C2
Total Entries C Total Slips 7FCAB
F3 T>/TV4
Reassigned Sectors List
Entries: 0001, Alts: 0000, Removed: 0000, Pending: 0006
Idx LBA PBA LLLCHS of LBA PLPCHS of PBA SFI Hours Msecs Status BBM Mask
0000 000013BF93C1 00001D32E045 ------.-.---- 040CBE.1.008E 07C5D4 ----- ------ 00010000 00001111
F3 T>/TV40
Nonresident GList 9 entries returned
Total entries available: 9
PBA Len Flags Phy Cyl Hd PhySctr SFI
13C0466A 488 0 2673B 2 0 67204
13C04C14 122 0 26736 2 0 D9336
13C05524 122 0 2672E 2 0 A9BEE
13CADC46 122 0 268BA 2 0 6AC6C
13CAE1F0 244 0 268B5 2 0 DCD9E
13CAE9DE 244 0 268AE 2 0 9694C
13CAF0AA 122 0 268A8 2 0 397F0
13CB01A8 122 0 26899 2 0 A9BEE
13CB03EC 122 0 26897 2 0 D7602
F3 T>/2x0
User Partition
LBAs 00000000-1D326C3F
PBAs 00000000-1D5B8470
HdSkew 006E, CylSkew 0032
ZonesPerHd 11
Head 0, PhyCyls 000000-041644, LogCyls 000000-040A5E
Physical Logical Sec Sym Sym Data
Zn Cylinders Cylinders Track Wedge Track Rate
00 000000-003670 000000-003670 0193 09D5 0013B5E8 1625.156
01 003671-0076C6 003671-0076C6 0188 0992 00133200 1582.968
02 0076C7-00C028 0076C7-00C028 0175 0925 00125F58 1514.531
03 00C029-010C88 00C029-010C88 016B 08E2 0011D978 1471.406
04 010C89-015A76 010C89-015A76 015B 0882 00112068 1412.343
05 015A77-019C1E 015A77-019C1E 0158 086D 0010F518 1398.750
06 019C1F-01E240 019C1F-01E240 0150 0830 00107EF8 1360.312
07 01E241-02291E 01E241-02291E 0140 07D8 000FCFC0 1304.062
08 02291F-026B76 02291F-026B76 012B 0755 000ECDD8 1220.625
09 026DB7-02B2B6 026B77-02B076 0120 070C 000E4018 1175.156
0A 02B2B7-02F10E 02B077-02EECE 010B 068E 000D4610 1095.000
0B 02F10F-03286D 02EECF-03262D 0100 064B 000CC420 1052.812
0C 03286E-0360F9 03262E-035EB9 00F4 05FF 000C2E80 1005.000
0D 0360FA-039079 035EBA-038E39 00E5 059F 000B7180 943.593
0E 03907A-03BEBB 038E3A-03BC7B 00DD 0570 000B14F8 914.062
0F 03BEBC-03EFAC 03BC7C-03ED6C 00CD 050D 000A5210 851.718
10 03EFAD-041644 03ED6D-040A5E 00C6 04E0 0009FB70 823.593
Head 1, PhyCyls 000000-0415EE, LogCyls 000000-040A7E
00 000000-003623 000000-003623 019B 0A0E 00142818 1662.187
01 003624-0074B7 003624-0074B7 0193 09D5 0013BBD0 1627.500
02 0074B8-00BB56 0074B8-00BB56 0185 0983 00131868 1574.531
03 00BB57-010616 00BB57-010616 0181 096A 0012E928 1559.062
04 010617-015125 010617-015125 016D 08EE 0011F310 1479.843
05 015126-0191C5 015126-0191C5 0162 08A9 00116F28 1437.656
06 0191C6-01D845 0191C6-01D845 0152 0848 0010AE38 1375.781
07 01D846-021F23 01D846-021F23 0143 07EB 000FF720 1316.250
08 021F24-02622B 021F24-02622B 0133 0786 000F3240 1252.968
09 02646C-02AA7F 02622C-02A83F 0120 070C 000E4018 1175.156
0A 02AA80-02EACF 02A840-02E88F 0112 06B9 000D9CB0 1122.187
0B 02EAD0-0323F0 02E890-0321B0 0105 0668 000CFD38 1071.562
0C 0323F1-035E97 0321B1-035C57 00F6 060B 000C4620 1012.031
0D 035E98-038F17 035C58-038CD7 00E5 059F 000B7180 943.593
0E 038F18-03BD59 038CD8-03BB19 00D9 0556 000ADFD0 897.187
0F 03BD5A-03EF56 03BB1A-03ED16 00CD 050D 000A5210 851.718
10 03EF57-0415EE 03ED17-040A7E 00C6 04E0 0009FB70 823.593
Head 2, PhyCyls 000000-041C71, LogCyls 000000-041161
00 000000-00370A 000000-00370A 0193 09D5 0013B5E8 1625.156
01 00370B-0077BA 00370B-0077BA 018C 09AD 00136920 1600.312
02 0077BB-00C0B7 0077BB-00C0B7 017E 0959 0012C3C0 1547.343
03 00C0B8-010D17 00C0B8-010D17 0172 090D 00122E20 1499.062
04 010D18-015B05 010D18-015B05 015F 0896 001145D0 1424.531
05 015B06-019D05 015B06-019D05 0155 085A 0010CFB0 1386.562
06 019D06-01E441 019D06-01E441 0143 07EA 000FF330 1315.312
07 01E442-022BDB 01E442-022BDB 0134 078B 000F3630 1254.375
08 022BDC-026E8B 022BDC-026E8B 0122 071D 000E5F98 1185.468
09 0270CC-02B6DF 026E8C-02B49F 0117 06D8 000DDDA8 1143.281
0A 02B6E0-02F687 02B4A0-02F447 0109 0681 000D2C78 1086.562
0B 02F688-032F5D 02F448-032D1D 00FD 0639 000C9EB8 1041.093
0C 032F5E-0368D0 032D1E-036690 00EF 05E0 000BEF80 984.375
0D 0368D1-039810 036691-0395D0 00E0 0580 000B3088 922.968
0E 039811-03C5D6 0395D1-03C396 00D9 0556 000ADFD0 897.187
0F 03C5D7-03F641 03C397-03F401 00C9 04F2 000A1CE8 834.375
10 03F642-041C71 03F402-041161 00BF 04B5 0009A4D0 795.468
Head 3, PhyCyls 000000-041E58, LogCyls 000000-04136C
00 000000-003670 000000-003670 0180 0963 0012D578 1552.968
01 003671-0076C6 003671-0076C6 0174 0918 00123FD8 1504.687
02 0076C7-00BEF9 0076C7-00BEF9 0168 08CA 0011A840 1455.937
03 00BEFA-010AF1 00BEFA-010AF1 0159 0873 0010FCF8 1401.093
04 010AF2-0158DF 010AF2-0158DF 0150 083B 00109A88 1369.218
05 0158E0-019A87 0158E0-019A87 0148 0807 00102858 1332.656
06 019A88-01E165 019A88-01E165 0130 0773 000F04F8 1238.437
07 01E166-0228FF 01E166-0228FF 0126 0732 000E8500 1197.187
08 022900-026C07 022900-026C07 0118 06DB 000DD9B8 1142.343
09 026E48-02B4B7 026C08-02B277 0108 067A 000D1AC0 1080.937
0A 02B4B8-02F4B3 02B278-02F273 00F6 0610 000C4C08 1014.843
0B 02F4B4-032E1F 02F274-032BDF 00E9 05BB 000BAC90 962.812
0C 032E20-0368C6 032BE0-036686 00DD 056F 000B0D18 911.250
0D 0368C7-039906 036687-0396C6 00CF 0518 000A61D0 856.406
0E 039907-03C70A 0396C7-03C4CA 00C2 04C9 0009C648 806.250
0F 03C70B-03F8C4 03C4CB-03F684 00B7 0483 00093C78 761.718
10 03F8C5-041E58 03F685-04136C 00AE 044C 0008D030 727.031
Head 4, PhyCyls 000000-045C94, LogCyls 000000-0450E8
00 000000-003AF3 000000-003AF3 017C 094B 0012A440 1537.031
01 003AF4-007F81 003AF4-007F81 0174 0918 00123FD8 1504.687
02 007F82-00CC70 007F82-00CC70 0168 08CA 0011A840 1455.937
03 00CC71-011CE0 00CC71-011CE0 0160 089D 00114FA8 1427.343
04 011CE1-016EE8 011CE1-016EE8 0154 0853 0010BFF0 1380.937
05 016EE9-01B508 016EE9-01B508 0148 0807 00102858 1332.656
06 01B509-02004E 01B509-02004E 0139 07AD 000F7728 1275.000
07 02004F-024BF2 02004F-024BF2 012D 0761 000EE770 1229.062
08 024BF3-02931A 024BF3-02931A 011D 06FD 000E1EA0 1164.375
09 02955B-02DF62 02931B-02DD22 010D 0699 000D5BB8 1101.562
0A 02DF63-0322FA 02DD23-0320BA 00FE 063C 000CA2A8 1042.031
0B 0322FB-035EBE 0320BB-035C7E 00F4 05FF 000C2A90 1003.125
0C 035EBF-039B80 035C7F-039940 00E1 0588 000B3E50 927.187
0D 039B81-03CE00 039941-03CBC0 00D8 054D 000ACC20 890.625
0E 03CE01-03FF68 03CBC1-03FD28 00D1 0525 000A7D60 865.312
0F 03FF69-0433C0 03FD29-043180 00C4 04D3 0009DBF0 813.281
10 0433C1-045C94 043181-0450E8 00B9 0490 00095808 770.625
Head 5, PhyCyls 000000-04603F, LogCyls 000000-045463
00 000000-003AA6 000000-003AA6 0184 097D 001306B0 1568.906
01 003AA7-007F34 003AA7-007F34 017A 0939 001280D0 1525.781
02 007F35-00CBBE 007F35-00CBBE 016E 08F8 001208B8 1487.343
03 00CBBF-011C96 00CBBF-011C96 0164 08B5 001180E0 1443.281
04 011C97-016E35 011C97-016E35 015F 0896 001145D0 1424.531
05 016E36-01B245 016E36-01B245 0148 0807 00102858 1332.656
06 01B246-01FD2D 01B246-01FD2D 0136 0797 000F4BD8 1261.406
07 01FD2E-024873 01FD2E-024873 0128 0742 000EA678 1207.968
08 024874-028F43 024874-028F43 011D 06FD 000E1EA0 1164.375
09 029184-02DB8B 028F44-02D94B 0110 06AB 000D7D30 1112.343
0A 02DB8C-031FCB 02D94C-031D8B 0101 0650 000CCA08 1054.687
0B 031FCC-035CBB 031D8C-035A7B 00F1 05EC 000C0528 990.937
0C 035CBC-039B98 035A7C-039958 00E4 059B 000B65B0 940.312
0D 039B99-03CF58 039959-03CD18 00D8 054D 000ACC20 890.625
0E 03CF59-04017A 03CD19-03FF3A 00CC 0507 000A4250 846.093
0F 04017B-04369B 03FF3B-04345B 00BE 04AF 00099510 790.312
10 04369C-04603F 04345C-045463 00B5 0478 000928C8 755.625
F3 2>/2T880
WARNING: Drive MC Area has been modified by serial port.
MC area must be re-initialized to ensure MC control data is valid
DO NOT SHIP WITHOUT FIRST RE-INITIALIZE MC AREA!
Cyl Head MnZn Throughput
Hd Zn Skew Skew Skew (MB/s)
0 00 32 6E 69 150.538
0 01 32 6E 69 146.432
0 02 32 6E 69 139.371
0 03 32 6E 69 135.613
0 04 32 6E 69 129.637
0 05 32 6E 69 128.512
0 06 32 6E 69 125.520
0 07 32 6E 69 119.544
0 08 32 6E 69 111.713
0 09 32 6E 69 107.594
0 0A 32 6E 69 99.756
0 0B 32 6E 69 95.658
0 0C 32 6E 69 91.165
0 0D 32 6E 69 85.566
0 0E 32 6E 69 82.578
0 0F 32 6E 69 76.600
0 10 32 6E 69 73.981
1 00 32 6E 69 153.508
1 01 32 6E 69 150.546
1 02 32 6E 69 145.316
1 03 32 6E 69 129.076
1 04 32 6E 69 136.349
1 05 32 6E 69 132.246
1 06 32 6E 69 126.288
1 07 32 6E 69 120.680
1 08 32 6E 69 114.685
1 09 32 6E 69 107.594
1 0A 32 6E 69 91.724
1 0B 32 6E 69 97.502
1 0C 32 6E 69 91.910
1 0D 32 6E 69 85.561
1 0E 32 6E 69 81.083
1 0F 32 6E 69 76.597
1 10 32 6E 69 73.996
2 00 32 6E 69 150.555
2 01 32 6E 69 121.340
2 02 32 6E 69 142.708
2 03 32 6E 69 112.411
2 04 32 6E 69 117.455
2 05 32 6E 69 94.742
2 06 32 6E 69 120.734
2 07 32 6E 69 115.076
2 08 32 6E 69 108.354
2 09 32 6E 69 104.280
2 0A 32 6E 69 99.047
2 0B 32 6E 69 94.544
2 0C 32 6E 69 89.301
2 0D 32 6E 69 75.047
2 0E 32 6E 69 81.116
2 0F 32 6E 69 75.149
2 10 32 6E 69 71.376
3 00 32 6E 69 143.430
3 01 32 6E 69 138.970
3 02 32 6E 69 134.475
3 03 32 6E 69 128.888
3 04 32 6E 69 125.496
3 05 32 6E 69 122.532
3 06 32 6E 69 113.567
3 07 32 6E 69 109.830
3 08 32 6E 69 104.605
3 09 32 6E 69 98.609
3 0A 32 6E 69 91.948
3 0B 32 6E 69 87.072
3 0C 32 6E 69 82.573
3 0D 32 6E 69 77.342
3 0E 32 6E 69 72.505
3 0F 32 6E 69 68.392
3 10 32 6E 69 65.031
4 00 32 6E 69 141.940
4 01 32 6E 69 138.958
4 02 32 6E 69 134.497
4 03 32 6E 69 131.490
4 04 32 6E 69 127.022
4 05 32 6E 69 122.540
4 06 32 6E 69 116.933
4 07 32 6E 69 112.453
4 08 32 6E 69 106.479
4 09 32 6E 69 100.500
4 0A 32 6E 69 94.899
4 0B 32 6E 69 91.165
4 0C 32 6E 69 84.072
4 0D 32 6E 69 80.705
4 0E 32 6E 69 78.100
4 0F 32 6E 69 73.251
4 10 32 6E 69 69.141
5 00 32 6E 69 144.943
5 01 32 6E 69 141.199
5 02 32 6E 69 136.751
5 03 32 6E 69 132.987
5 04 32 6E 69 131.118
5 05 32 6E 69 122.546
5 06 32 6E 69 115.815
5 07 32 6E 69 110.589
5 08 32 6E 69 106.479
5 09 32 6E 69 101.618
5 0A 32 6E 69 96.022
5 0B 32 6E 69 90.046
5 0C 32 6E 69 85.194
5 0D 32 6E 69 80.701
5 0E 32 6E 69 76.236
5 0F 32 6E 69 70.983
5 10 32 6E 69 67.646
linkxin88
2017-3-31 20:52
高手指点下
linkxin88
2017-4-3 21:13
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA。。。。。。。。。。。。。。。。。。。。。。。
笔记本维修新手
2017-4-4 00:36
段位很好,试试清smart g表,在重建译码器
linkxin88
2017-4-4 23:42
10楼帅哥,重建泽码器这个功能是哪个软件
linkxin88
2017-4-4 23:45
本人对这个软件功能不太清楚,重建译码器功能在哪?
linkxin88
2017-4-4 23:47
有没可以备份固件的工具?要新点盘能支持的最好
linkxin88
2017-4-5 21:38
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa....
linkxin88
2017-4-6 21:41
来啊,来人啊。。。。
白如墨
2017-4-7 19:56
短接试试
linkxin88
2017-4-9 20:49
这个可以的
linkxin88
2017-4-9 20:52
看来对希捷盘没有什么好方法,我还有一堆有坏道的西数,苦于没有好的良方
laiguanjia
2017-4-10 07:36
F3的盘不是这么容易搞的
liuguochang
2017-4-13 16:05
这个得有工具才能搞定,你这是报MCMT错误
