标题: LCD1602液晶显示屏 [打印本页]
作者: バ幸福De右岸    时间: 2017-2-8 12:34
标题: LCD1602液晶显示屏
下载附件  [url=]保存到相册[/url]
LCD1602原理图
[color=rgb(153, 153, 153) !important]2017-2-7 00:57 上传
以下是程序:
#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
sbit rs=P2^0;
sbit rw=P2^1;
sbit lcden=P2^2;
sbit k1=P3^2;
sbit k2=P3^3;
sbit k3=P3^4;
sbit k4=P3^5;
uchar code table[]=" 2017/02/07 TUE";
uchar code table1[]="    00:00:00";
uchar count,shi,fen,miao,k1num;
void delay(uchar x)
        uint y;
        for(;x>0;x--)
                for(y=100;y>0;y--);
void write_com(uchar com)
        rs=0;
        rw=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar dat)
        rs=1;
        rw=0;
        lcden=0;
        P0=dat;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_sfm(uchar add,uchar dat)
        uchar shi,ge;
        shi=miao/10;
        ge=miao%10;
        write_com(0x80+0x40+add);
        write_data(0x30+shi);
        write_data(0x30+ge);
void init()
        uchar num;
        shi=0;
        fen=0;
        miao=0;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        for(num=0;num<15;num++)
                write_data(table[num]);
                delay(5);
        write_com(0x80+0x40);
        for(num=0;num<12;num++)
                write_data(table1[num]);
                delay(5);
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void keyscan()
        if(k1==0)
                delay(5);
                if(k1==0)
                        while(!k1);
                        TR0=0;
                        write_com(0x80+11);
                        write_com(0x0f);
void main()
        init();
        while(1)
                keyscan();
                if(count==20)
                        count=0;
                        miao++;
                        if(miao==60)
                                miao=0;
                                fen++;
                                if(fen==60)
                                        fen=0;
                                        shi++;
                                        if(shi==24)
                                                shi=0;
                                        write_sfm(4,shi);
                                write_sfm(7,fen);
                 write_sfm(10,miao);
void timer0() interrupt 1
        count++;
