作者: fdgdsdsadsaf 时间: 2016-11-26 21:51
LED灯珠短路了吧作者: 陈艳军 时间: 2016-11-26 22:29
换个屏试试作者: huangmaohong520 时间: 2016-11-26 23:05
LED 灯管颗粒有问题吧。 换LED灯管就可以了作者: pcbfixer88 时间: 2016-11-26 23:47
These resistors complete backlight LED current sense( current measuring) circuits. When you remove resistors, the current sensing circuit is open and surely you have one side (that connects to backlight LED) has high voltage and the other side has nothing.作者: 代子易 时间: 2016-11-26 23:55
围观看看再说作者: 感性馨儿 时间: 2016-11-27 00:31
