标题: ACER v5-471不出3V,5V求助 [打印本页]
作者: ae鸟维修 时间: 2016-10-17 20:29
有人可能要说1脚6脚不正常,但我翻了下数据手册
The GND − PHASE1
current limit threshold is 1/10th the voltage seen at ENTRIP1 over a 0.515V to 3V
range. There is an internal 10μA current source from VREG5 to ENTRIP1. Leave
ENTRIP1 floating or drive it above 4.5V to shut down channel 1.
说明是正常的。
求大神指点一下。
附上RT8223M的数据手册
RT8223L RT8223M DS8223LM-04.pdf
(391.99 KB, 下载次数: 8)
