标题: hp g62-a32ee dead [打印本页]
作者: johncarter 时间: 2016-9-19 21:04
Today I am sharing hp g62-a32ee { foxconn pm_i_hpc_s mv_mb_v3 } no power issue…
Attached psu its take 0.002 amps when u swithed on its take0.024 amps and off no lights blinking..
Then check 3v pcu its came 3.3v and check 5v pcu its 0v butwhen u switched on its came 5v and within second its 0v
In this kind of problem I always check on i/o chip acav _in[here is acpres] its always high but here its low.
So check dcin on max8731 its came 19v
then check max8731 LDOits 0v
That’s a problem LDO not come that means its max 8731 isfaulty
Just replace max8731 and fix the problem…..thanks..
now check on ldo its 5v and acav _in [here is acpres] its also came 3,3v
and also check load on power supply unit its a 0.024 and adptor in indicator light is blinking...
作者: 梁山人 时间: 2016-9-19 21:16
Good!You just made it! I need learn from you.Get my admire!
作者: 戴眼镜的色鬼 时间: 2016-9-19 21:21
哎 哥只能看图了 俗话说得好“ 从小不学好,长大修电脑”
作者: 梁山人 时间: 2016-9-19 21:25
这是个褒意吧
意思是从小没学好,但长大了还会修电脑,说明你天资不错。
作者: zhangxunhai 时间: 2016-9-19 21:27
max 8731芯片坏了
作者: H55 时间: 2016-9-19 21:36
哦哦,, MAX充电芯片爆掉了 LDO爆掉
作者: zh19920520x 时间: 2016-9-19 22:02
where are you form?
作者: zhyz999 时间: 2016-9-19 22:11
基本上我看一次就可以理解英语还是不错的
作者: 宫泽熙 时间: 2016-9-19 22:11
Why are you so diao
作者: 87957907 时间: 2016-9-20 14:42
学习学习!!!!!!!!!!!
作者: 新芯箱硬88 时间: 2016-9-20 14:54
慢慢研究我 我看到就点头痛,好几天没有遇到机器了
作者: 会员945875 时间: 2016-9-20 15:03
我看不懂啊
作者: 天夜叉 时间: 2016-9-20 15:14
楼主技术很厉害,到芯片级了吗?
作者: 28893589 时间: 2016-9-20 15:51
高手呀.带徒弟么?
作者: zhouxiaobao9 时间: 2016-9-20 16:05
这仁兄是老外吗?
作者: 坚强者胜 时间: 2016-9-25 14:57
楼主最后怎么了解决的
Powered by Discuz! X3.4 |
