- 功 能:读取序列号并匹配序列号,并读温度值
- 多功能试验板显示多路温度采集
- 正常显示2个DS18B20温度
- 正常读取DS18B20序列号
- 单片机:STC12C5A60S2
- 晶 振:11.0592M
- 作 者:苏义江改编自网络
- 时 间:2016-8-25
- #include <reg52.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit RS=P2^7;
- sbit RW=P2^6;
- sbit EN=P2^5;
- sbit DQ=P3^4; //传感器引脚
- sbit key=P3^7;
- sbit d1=P1^3;//指示灯
- sbit d2=P1^4;
- bit st=1;
- uchar code table0[]={"DuoLuWenDuXS:U "};
- uchar code table2[]={"SD: "}; //湿度
- uchar code table1[]={"0123456789ABCDEF"};
- //现有的2个DS18B20传感器的序列号ROM1,ROM2
- uchar DSrom[4][8]={//4个器件每个64位序列号
- {0x28,0xff,0x2a,0x0A,0x22,0x04,0x00,0xf6},//ROM1
- {0x28,0xFF,0x0b,0x0d,0x20,0x04,0x00,0x0a},//ROM2
- {0x28,0x0C,0xBA,0xBA,0x02,0x00,0x00,0x54},//ROM3
- {0x28,0xff,0x91,0x14,0x22,0x04,0x00,0xe4}//ROM4
- int f[4]; //温度数组
- int tvalue; //温度值变量
- float ftvalue; //温度值变量
- uchar fCode[8];//序列号数组
- uint warnl=300; //设定温度值高
- uint warnh=992;//设定温度值低
- void ds1820wr(uchar dat);//写数据
- void ds1820rst();//ds1820复位
- uchar ds1820rd();//读数据
- void DispCode();//读取序列号
- uchar tflag;//温度正负标志
- //////////lcd1602程序////////////
- void delay1ms(uint ms)//延时1毫秒(不够精确的)
- uint i,j;
- for(i=0;i<ms;i++)
- for(j=0;j<620;j++);
- void wr_com(uchar com)//写指令//
- delay1ms(1);
- RS=0;
- RW=0;
- EN=0;
- P0=com;
- delay1ms(1);
- EN=1;
- delay1ms(1);
- EN=0;
- void wr_dat(uchar dat)//写数据//
- delay1ms(1);;
- RS=1;
- RW=0;
- EN=0;
- P0=dat;
- delay1ms(1);
- EN=1;
- delay1ms(1);
- EN=0;
- void lcd_init()//1602初始化设置//
- delay1ms(15);
- wr_com(0x38);
- delay1ms(5);
- wr_com(0x08);delay1ms(5);
- wr_com(0x01);delay1ms(5);
- wr_com(0x06);delay1ms(5);
- wr_com(0x0c);delay1ms(5);
- void display(uchar *p)//显示字符串
- while(*p!='\0')
- wr_dat(*p);
- p++;
- delay1ms(1);
- void displayinit()//初始化显示
- lcd_init();
- wr_com(0x80);
- display(table0);
- wr_com(0xC6);
- wr_dat(0xdf);
- wr_com(0xC7);
- wr_dat('C');
- wr_com(0xCf);
- wr_dat(0x25);
- wr_com(0XC9);
- display(table2);
- void tmstart()//初始化ds18b20
- DQ=1;
- d1=1;
- d2=1;
- ds1820rst();
- delay1ms(1);
- ds1820wr(0xcc);
- ds1820wr(0x44);
- void read_dealtemp()//读取并处理温度
- uchar i,j,t;
- uchar a,b;
- for(j=0;j<5;j++) //挂载4个设备
- ds1820rst(); //复位
- delay1ms(1);
- ds1820wr(0x55); //匹配EOM指令
- for(i=0;i<8;i++)
- ds1820wr(DSrom[j]);//发送64位序列号
- ds1820wr(0xbe);//温度转换
- a=ds1820rd(); //读高位
- b=ds1820rd(); //读低位
- tvalue=b;
- tvalue<<=8;
- tvalue=tvalue|a;
- if(tvalue<0) //判断正负温度
- d1=1;
- tvalue=~tvalue+1;
- wr_com(0xc0); //第二行第一列
- wr_dat(0x2d); //负温度符号"-"
- if(tvalue<warnl) //温度高于设定值warnl=300;
- d2=0; //报警
- DQ=0;
- else
- d2=1;
- DQ=1;
- else
- d2=1;
- wr_com(0xc0);
- wr_dat(' ');
- if(tvalue>warnh) //温度高于设定值warnh=992;
- d1=0; //报警
- DQ=0;
- else
- d1=1;
- DQ=1;
- if(j==0)
- wr_com(0x8f);
- wr_dat('1');
- if(j==1)
- wr_com(0x8f);
- wr_dat('2');
- if(j==2)
- wr_com(0x8f);
- wr_dat('3');
- if(j==3)
- wr_com(0x8f);
- wr_dat('4');
- if(j==4)
- wr_com(0x8f);
- wr_dat('5');
- ftvalue=tvalue*0.0625;
- tvalue=ftvalue*10+0.5;
- ftvalue=ftvalue+0.05; //温度补偿
- f[j]=tvalue;//温度扩大十倍,精确到一位小数
- tvalue=f[j];
- t=tvalue/1000;
- wr_com(0x80+0x41);
- wr_dat(table1[t]);//显示百位
- t=tvalue%1000/100;
- wr_dat(table1[t]);//显示十位
- t=tvalue%100/10;
- wr_dat(table1[t]);//显示个位
- wr_dat(0x2e); //显示小数点儿
- t=tvalue%10/1;
- wr_dat(table1[t]);//显示小数位
- delay1ms(5000);
- void keyscan()//按键
- if(key==0)
- delay1ms(30);
- if(key==0)
- st=~st;
- while(!key);
- void main()
- d1=1;
- d2=1;
- DQ=1;
- displayinit();//初始化显示
- while(1)
- keyscan();//按住按键等4个器件循环完毕显示序列号
- if(st==1)
- wr_com(0x01);
- tmstart();//初始化
- read_dealtemp();//读取温度
- else
- wr_com(0x01);
- DispCode();//读取序列号
- delay1ms(1000);
- ////////DS18B20函数///////////////
- void delay_b20(uint n)//STC12C5A单片机定时1us
- while(n--)
- _nop_();
- void ds1820rst()/*ds1820复位*/
- uchar x=0;
- DQ = 1; //DQ复位
- delay_b20(1); //延时
- DQ = 0; //DQ拉低
- delay_b20(500); //精确延时大于480us
- DQ = 1; //拉高
- delay_b20(80);
- uchar ds1820rd()/*读数据*/
- uchar i=0;
- uchar dat = 0;
- for (i=0;i<8;i++)
- DQ = 1; //给脉冲信号
- delay_b20(1);
- DQ = 0; //给脉冲信号
- delay_b20(1);
- dat>>=1;
- DQ = 1; //给脉冲信号
- if(DQ)
- dat|=0x80;
- delay_b20(60);
- return(dat);
- void ds1820wr(uchar dat)/*写数据*/
- uchar i=0;
- for (i=0; i<8; i++)
- DQ = 1;
- delay_b20(1);
- DQ = 0;
- DQ = dat&0x01;
- delay_b20(60);
- DQ = 1;
- delay_b20(60);
- dat>>=1;
- delay_b20(1);
- ///////////读取序列号//////////
- void DispCode()//读取序列号
- uchar i,temp;
- ds1820rst();
- ds1820wr(0x33);
- for (i=0;i<8;i++)
- fCode=ds1820rd();
- wr_com(0x80+0x40);
- for (i=0;i<8;i++)
- temp = fCode>>4; //显示高四位
- if (temp<10)
- wr_dat(temp + 0x30); // 显示数字
- else
- wr_dat(temp + 0x37); //否则大于数字9显示字母
- temp = fCode&0x0f;//显示低四位
- if (temp<10)
- wr_dat(temp+ 0x30);
- else
[color=rgb(85, 85, 85) !important]复制代码
