Ñ¸Î¬Íø
²é¿´: 12780|»Ø¸´: 24
´òÓ¡ ÉÏÒ»Ö÷Ìâ ÏÂÒ»Ö÷Ìâ
[±Ê¼Ç±¾]
Èʱ¦Ðµã»ð»ØÂ·½²½â
     ¹Ø±Õ [¸´ÖÆÁ´½Ó]
Ìø×ªµ½Ö¸¶¨Â¥²ã
·¢±íÓÚ 2012-10-22 12:01:44 | Ö»¿´¸Ã×÷Õß »ØÌû½±Àø |µ¹Ðòä¯ÀÀ |ÔĶÁģʽ À´×Ô£º ¹ã¶« À´×Ô ¹ã¶«
ÂíÉÏ×¢²á£¬»ñÈ¡ÔĶÁ¾«»ªÄÚÈݼ°ÏÂÔØÈ¨ÏÞ
ÄúÐèÒª µÇ¼ ²Å¿ÉÒÔÏÂÔØ»ò²é¿´£¬Ã»ÓÐÕʺţ¿×¢²á
¼ÌÉϴη¢¹ý¼¸¸öͼºó£¬¼òµ¥Ð©ÁËÏ·ÖÎö¹ý³Ì£¬±¾È˷ǵç×Óרҵ±ÏÒµ£¬ÓÐЩµØ·½¿´µÄ¶®µ«²»ÖªµÀ¸ÃÈçºÎ±í´ï¡£×©Í·ÇëÇáÅÄлл¡£¹àË®ÇëÈÆÐУ¡
=======================Ñ¸Î¬Íø Ô±ýÔ­´´===========================
    ÔÚGM45ϵÁÐÒÔÉϵÄÈʱ¦Ö÷°åÖУ¬±£»¤¸ôÀëºÍµã»ð»ØÂ·µç·ÓÐËù¸Ä±ä¡£
    ÒÔLA-6631PΪÀý£¬¿´ÏÂÃæµÄ·ÖÎö£ºVINÔ½¹ýËĸö²¢ÁªµÄµç×èµ½´ïPRECHG£¬´Ëµçѹһ·¾­¹ýPD7ºÍPQ27µ½B+£¬Áíһ·¾­¹ýPR43ºÍPR47·ÖѹºóË͸øPU4(ISL6251)µÄACSET½Å¡£
    µ±¸ÕÊÊÅäÆ÷¹©µçģʽÏ£¬ACOFFΪµÍ£¬´Ëʱ+5VALWPҲδ²úÉú£¬PD9ÎÞ·¨Ê¹PQ28µ¼Í¨£¬ËùÒÔPQ30½«»áµ¼Í¨£¬Ê¹PR83ºÍPR86·ÖѹÐγÉÏà¶ÔµÍµçƽ£¬Ð¡µçÁ÷µÄB+²úÉú¡£ÔÚµç³Ø¹©µçʱ£¬ACOFFΪ¸ß£¬»òÕß+5VALWPÕý³£²úÉúºó£¬´Ëµç·¶¼»á¹Ø±Õ¡£Èç¹ûB+´æÔÚ¶Ì·£¬µçѹ±»À­µÍ£¬ÄÇôPRECHGͬÑù»á±»À­µÍΪ£¬¾ßÌåµçѹ±ÈB+¸ß1V£¨¾­²é£¬LL4148ѹ½µ1V£©¡£PRECHG¾­¹ý·Öѹ£¬Ë͵½PU4(ISL6251)µÄACSET¡£
    ÔÚISL6251Êý¾ÝÊÖ²áÖÐÓÐ×¢Ã÷ÈçÏ£º
    ACSET
    ACSET is an AC adapter detection input. Connect to a resistor dividerfrom the AC adapter output.
    ACPRN
    Open-drain output signals AC adapter is present. ACPRN pulls lowwhen ACSET is higher than 1.26V; and pulled high when ACSET is lower than1.26V.
    ACSET¶¨ÒåΪACÊÊÅäÆ÷¼ì²âÊäÈë½ÅACPRN¶¨ÒåΪ¿ªÂ©Êä³ö½Å£¬µ±ACSET¸ßÓÚ1.26VʱACPRNÀ­µÍ£¬µ±ACSETΪµÍµçƽʱ£¬ACPRNÀ­¸ß
    Ò²¾ÍÊÇ˵ACSETµÄÃż÷ֵΪ1.26v£¬¾­¹ý·Öѹ¼ÆËã[1.26/PR47*(PR43+PR47)]¿ÉÒԵóöPRECHG²»ÄܵÍÓÚ18.09V£¬ÓÉÓÚB+ÊÇPRECHG¾­¹ýPD7²úÉúµÄ£¬ËùÒÔB+µçѹ×îµÍÏÞÖÆÎª17.09v
    ÈôB+²»´æÔÚ¶Ì·£¬PRECHGµçѹÕý³££¬ACSET³¬¹ý1.26v£¬ACPRNÊä³öµÍµçƽ£¬PQ26½«»á½ØÖ¹£¬PACINÓÉ6251VDD¾­¹ýPR72ºÍPR74·ÖѹµÃµ½¸ßµçƽ£¬Í¬Ê±ACIN¸ßµçƽË͸øEC
    ¸ßµçƽµÄPACIN¾­¹ýPR63ʹPQ20Bµ¼Í¨£¬VIN¾­¹ýPQ12Ìå¶þ¼«¹Ü²úÉúµÄP2¾­¹ýPR41ºÍPR50·Öѹ³É8V×óÓÒ£¬PQ12¡¢PQ13µ¼Í¨£¬VINÔ½¹ý±£»¤¸ôÀë²úÉú´óµçÁ÷B+¡£
    ÈôECδÄܼì²âµ½ACIN£¬»òÕßµç³Ø¹©µçʱ£¬ACOFFΪ¸ß£¬PQ24µ¼Í¨£¬À­µÍPQ20µÄG¼«£¬VIN_1ʹPQ17µ¼Í¨£¬´Ó¶øP2¾­¹ýPQ15ÄÚ²¿µç×è·Öѹ£¬PQ15ÊÇPNP¹Ü£¬B¼«µçѹСÓÚE¼«£¬E-Cµ¼Í¨£¬½«P2Ö±½Óµ¼Í¨µ½PQ12ºÍPQ13µÄG¼«£¬Á½¸öP¹µµÀ¹Ü¶¼»á±»¹Ø±Õ¡£VINÓëB+±»¸ôÀë¡£
    ÁíÍ⣬ACPRNΪµÍµçƽºó£¬PQ10½ØÖ¹£¬VS¾­¹ýPR36ʹPQ9µ¼Í¨£¬À­µÍPQ8µÄG¼«£¬PQ8½ØÖ¹£¬ENTRIP1ºÍENTRIP2²»½ÓµØ£¨×¢£ºVSÖ»ÓÐÔÚÊÊÅäÆ÷ģʽÏÂÖ±½Ó²úÉú£¬¶øÔÚµç³ØÄ£Ê½ÏÂÐèÒª´¥·¢¿ª¹Øºó²Å»á²úÉú£¬ÁíÈô´æÔÚ¹ýΣ¬MAINPWONΪµÍ£¬Ò²»á½ØÖ¹PQ9£¬Õâ¸öÓëLA-3541PûÓÐÇø±ð£¬²»ÔÙ²ûÊö£©
    RT8205µÄENTRIP1ºÍENTRIP2ûÓÐÖ±½Ó½ÓµØ£¬¶øÊÇͨ¹ýµç×è½ÓµØ£¬¿ÉÒÔ˳Àû²úÉú+3VALW¡¢+5VALW
    ÔÚRT8205µÄÊý¾ÝÊÖ²áÖж¨ÒåÁËENTRIP½ÅµÄ×÷ÓÃÊÇʹÄܺͼ«ÏÞµçÁ÷É趨£¬µ±´Ë½Å½ÓµØÊ±×÷ΪʹÄܽŹرÕÊä³ö£¬µ±´Ë½Å½Óµç×èÔÙ½ÓµØÊ±£¬×÷Ϊ¼«ÏÞµçÁ÷É趨¡£Ð¾Æ¬ÄÚ²¿´ÓVREG5ÒýÀ´10uAµçÁ÷Ô´¡£ENTRIP1 (Pin 1)Channel 1 enable and Current Limit setting Input. Connect resistorto GND to set the threshold for channel 1 synchronous RDS(ON) sense. TheGND-PHASE1 current-limit threshold is 1/10th the voltage seen at ENTRIP1 over a0.5V to 2V range. There is an internal 10uA current source from VREG5 toENTRIP1. The logic current limit threshold is default to 200mV value if ENTRIP1is higher than VREG5-1V.
==================¹ã¸æºÍ¸½¼þ=========================
¡¾Ñ¸  Î¬  Åࠠѵ  ÖР ÐÄ  Áª ϵ ·½ ʽ¡¿
Åàѵ×Éѯµç»°£º 0755-61506416 61506417
Ô´ÎļþÏÂÔØ£º
Èʱ¦Ðµã»ð»ØÂ·.pdf (485.04 KB, ÏÂÔØ´ÎÊý: 1128)
¹ºÂò¼Ç¼
¹ºÂòÈËÊý3¼Û¸ñ¹ºÂòʱ¼ä
 »áÔ±1484732300öζ¹2026-4-8 17:27
 »áÔ±11320980.5Ôª2018-10-19 09:33
 »áÔ±5040410.5Ôª2018-10-7 11:58
²é¿´ËùÓйºÂò¼Ç¼
ÆÀ·Ö
²ÎÓëÈËÊý 10ÏÂÔØ·Ö +115 ÊÕÆð ÀíÓÉ
bruce1323 + 5 Ö§³Ö±ý¸ç£¡
abc123194 + 5 ºÜ¸øÁ¦!
zhangmintao2008 + 5 ºÜÊÇȨÍþ£¬¶¥Ò»ÏÂ
ptmanager + 30
ÕÔÔÆ·ÉÕ + 10 ¸ø±ý¸çº°¼ÓÓÍ
ÃûÈË×ܵê + 10 Ò²¸ø±ý¸ç»Ø±¨Ò»µã ¹þ¹þ
wskihc10 + 10 ÕâÊÇÊ×´´
aww3856 + 5 ¶¥£¬
ÐÄÔÚ·ÉÏè + 30 ¶¥±ý¸çÁ¦×÷¡£
sfg-813 + 5
²é¿´È«²¿ÆÀ·Ö
±¾ÎÄÓÉ »áÔ±34709 Ô­´´»ò±»ÊÚÈ¨×ªÔØÖÆ×÷£¬ÆäËû»ú¹¹»ò¸öÈËδ¾­Ðí¿ÉÑϽû×ªÔØ¡£
·¢±íÓÚ 2012-10-22 12:29:22 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«ÉîÛÚ À´×Ô ¹ã¶«ÉîÛÚ
ÎÒÊÇɳ·¢£¿£¿   ÒÔǰ¾­³£Óöµ½¹ý£¬µ«Ã»ÓÐϸϸȥ·¢ÏÖеã»ð»ØÂ·£¬ÏµÍ³µÄѧϰÁËһϣ¬²¦¿ªÔÆÎí¼ûÇàÌì°¡¡£ÐÂÊÖ»¹ÊǵÃϸϸ¿´£¬×îºÃ¿ª¸öͼֽ¿´£¬²»È»Ò²»á¿´Ôεġ£
3#
·¢±íÓÚ 2012-10-22 12:53:36 | Ö»¿´¸Ã×÷Õß À´×Ô£º ½­ËÕÄϾ© À´×Ô ½­ËÕÄϾ©
¸ÐлÔ±ýÀÏʦ·ÖÏíÕâôºÃµÄ×ÊÁÏ£¡
4#
·¢±íÓÚ 2012-10-22 13:01:55 | Ö»¿´¸Ã×÷Õß À´×Ô£º ÖØÇì À´×Ô ÖØÇì
ACINµÄ²úÉú·½Ê½±äÁË
5#
·¢±íÓÚ 2012-10-22 13:18:24 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¸£½¨ÆÎÌï À´×Ô ¸£½¨ÆÎÌï
ÕâÑùÉè¼ÆºÃÏñ¸ü¼òµ¥ÁË£¬¶øÇÒÓ¦¸Ã±ÈÔ­À´µÄÎȶ¨²»ÈÝÒ×»µÁË
6#
·¢±íÓÚ 2012-10-22 13:57:12 | Ö»¿´¸Ã×÷Õß À´×Ô£º Õã½­ºþÖÝ À´×Ô Õã½­ºþÖÝ
±ý¸çÁ¦×÷£¬¶¥Ò»Ï¡£Ð°汾µÄȷʵ±ä¸üÁËһЩµØ·½
7#
·¢±íÓÚ 2012-10-22 14:41:55 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ãÎ÷ÄÏÄþ À´×Ô ¹ãÎ÷ÄÏÄþ
±ý¸ç£¬ÕâôºËÐĵÄÄÚÈݶ¼¹«²¼³öÀ´ÁË£¬´ó¼Ò¶¼²»ÓÃÈ¥»ùµØÁË£¬²»¹ýÒ²Óкô¦£¬×÷Ϊ¹úÄÚάÐÞ½ç´óÂÛ̳£¬Èô̳ÀïûÓÐһЩ¼¼Êõ¶«Î÷¸øÈËѧϰ£¬Ôò²»»áÓиßÈËÆø£¬¿öÇÒ£¬²¢²»ÊÇÿ¸öÈ˶¼¿´µÃ¶®µÄ{:soso_e113:}
µãÆÀ
»áµÄ£¬²»¿´Ò²»á£¬ ²»»áµÄ£¬»¹ÊÇÒªÀ´Ñ§Ï°²Å»áµÄ¡£  ÏêÇé »Ø¸´ ·¢±íÓÚ 2012-10-22 15:13
8#
·¢±íÓÚ 2012-10-22 15:13:08 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶« À´×Ô ¹ã¶«
guofenren ·¢±íÓÚ 2012-10-22 14:41
±ý¸ç£¬ÕâôºËÐĵÄÄÚÈݶ¼¹«²¼³öÀ´ÁË£¬´ó¼Ò¶¼²»ÓÃÈ¥»ùµØÁË£¬²»¹ýÒ²Óкô¦£¬×÷Ϊ¹úÄÚάÐÞ½ç´óÂÛ̳£¬Èô̳ÀïûÓÐ ...
»áµÄ£¬²»¿´Ò²»á£¬
Í·Ïñ±»ÆÁ±Î
9#
·¢±íÓÚ 2012-10-22 19:51:57 | Ö»¿´¸Ã×÷Õß À´×Ô£º Õã½­ÉÜÐË À´×Ô Õã½­ÉÜÐË
¸ú±ý¸çѧÍêÈýÆÚ£¬¾Í¿ÉÒÔÌìÌì³ÔÔ±ýÁË
10#
·¢±íÓÚ 2012-10-22 22:17:25 | Ö»¿´¸Ã×÷Õß À´×Ô£º ºÓ±±Ê¯¼Òׯ À´×Ô ºÓ±±Ê¯¼Òׯ
±ý¸çµÄ×öƽ ¶¼ÊǾ«Æ·
11#
·¢±íÓÚ 2012-10-22 22:38:32 | Ö»¿´¸Ã×÷Õß À´×Ô£º ±±¾© À´×Ô ±±¾©
{:4_136:}{:4_136:}À÷º¦ Ì«ÏêϸÁË
12#
·¢±íÓÚ 2012-10-22 23:05:16 | Ö»¿´¸Ã×÷Õß À´×Ô£º ÉÂÎ÷Î÷°² À´×Ô ÉÂÎ÷Î÷°²
Õâ¸öÒª×Ðϸ×ÁÄ¥Ò»ÏÂÁË¡£Ô±ýµÄ¼¼ÊõÎÄ×ÖÏ൱¸øÁ¦£¬ÈÏÕæÕûÀíµ½±Ê¼Ç±¾ÉÏ¡£
13#
·¢±íÓÚ 2012-10-22 23:36:49 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«¹ãÖÝ À´×Ô ¹ã¶«¹ãÖÝ
²»´íµÄÎÄÕ£¬Ñ§Ï°ÁË£¡µ«»¹ÊÇÓÐЩµØ·½²»¶®
14#
·¢±íÓÚ 2012-10-23 15:56:53 | Ö»¿´¸Ã×÷Õß À´×Ô£º ɽ¶«µÂÖÝ À´×Ô É½¶«µÂÖÝ
ACSET¶¨ÒåΪACÊÊÅäÆ÷¼ì²âÊäÈë½ÅACPRN¶¨ÒåΪ¿ªÂ©Êä³ö½Å£¬µ±ACSET¸ßÓÚ1.26VʱACPRNÀ­µÍ£¬µ±ACSETΪ¸ßµçƽʱ£¬ACPRNÀ­¸ß* M% x9 y& D! U  R2 Q. K
±¾ÎÄÀ´×Ô£ºÑ¸Î¬Íø£¨www.chinafix.com.cn£©£¬Ïêϸ³ö´¦²Î¿¼:http://www.chinafix.com.cn/forum ... read&tid=582186
Õâ¸öµØ·½£¬Óе㷭Òë´íÎó£¬Ó¦¸ÃÊǵ±ACSETΪµÍµçƽʱ¡£ACPRNÀ­¸ß
µãÆÀ
ллָ³ö¡£±ÊÎó¡£ºÇºÇ µ±ACSET¸ßÓÚ1.26VʱACPRNÀ­µÍ£¬µ±ACSETΪ¸ßµçƽʱ£¬ACPRNÀ­¸ß ¸ÄΪ µ±ACSET¸ßÓÚ1.26VʱACPRNÀ­µÍ£¬µ±ACSETΪµÍµçƽʱ£¬ACPRNÀ­¸ß  ÏêÇé »Ø¸´ ·¢±íÓÚ 2012-10-23 16:20
15#
·¢±íÓÚ 2012-10-23 16:20:33 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶« À´×Ô ¹ã¶«
¸¶ÂÀ½£Îä ·¢±íÓÚ 2012-10-23 15:56
ACSET¶¨ÒåΪACÊÊÅäÆ÷¼ì²âÊäÈë½ÅACPRN¶¨ÒåΪ¿ªÂ©Êä³ö½Å£¬µ±ACSET¸ßÓÚ1.26VʱACPRNÀ­µÍ£¬µ±ACSETΪ¸ßµçƽʱ£¬ ...
ллָ³ö¡£±ÊÎ󡣺ǺÇ
¸ÄΪ
16#
·¢±íÓÚ 2012-10-23 19:51:26 | Ö»¿´¸Ã×÷Õß À´×Ô£º ½­ËÕËÕÖÝ À´×Ô ½­ËÕËÕÖÝ
ûÓÐÒ»¶¨µÄ¹¦µ×£¬ºÜÄÑÀíÇåÕâ¸ö²úÉúµÄʱÐòÎÊÌâ...
17#
·¢±íÓÚ 2012-10-23 20:19:07 | Ö»¿´¸Ã×÷Õß À´×Ô£º ½­ËÕÎÞÎý À´×Ô ½­ËÕÎÞÎý
ÏÂÔØÀ´Ñо¿Ñо¿£¬Ð»Ð»Ô±ý
18#
·¢±íÓÚ 2012-10-23 21:46:59 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«¶«Ý¸ À´×Ô ¹ã¶«¶«Ý¸
±ý¸ç£¬ÉÏ´«µÄÒ»°ã¶¼ÊǾ­µä¡£Ïò±ý¸çѧϰ£¡£¡£¡
19#
·¢±íÓÚ 2012-10-24 11:39:56 | Ö»¿´¸Ã×÷Õß À´×Ô£º ËÄ´¨ À´×Ô ËÄ´¨
Ô±ýÀÏʦ¿´ÍêÄãµÄеã»ð»ØÂ·½²½âµÄÒÉÎÊ£¬Çë´Í½Ì£º
µ±Ö»ÓÃµç³ØÊ±£¬BATTÈçºÎת»»ÎªB+£¿Ò²¾ÍÊÇPQ14  B¼« ÈçºÎʵÏÖµÍµçÆ½£¿
ÊÇ·ñÊÇÎÞVIN¡¢VIN_1¡¢ACPRN¡¢£¨PACINºÍACOFFûÓõ½£©¾ÍÏ൱ÓÚPQ14µÄB¼«Îª0V,ËùÒÔPQ14¾ÍÍêÈ«µ¼Í¨£¿
µãÆÀ
ͬÒâÂ¥Ö÷: 5.0
ÊǵÄ,ûÓÐAC,vinΪÁãV  ÏêÇé »Ø¸´ ·¢±íÓÚ 2012-11-1 17:46
ͬÒâÂ¥Ö÷: 5
  ·¢±íÓÚ 2012-10-24 11:59
20#
·¢±íÓÚ 2012-10-27 09:12:32 | Ö»¿´¸Ã×÷Õß À´×Ô£º ¹ã¶«ÉîÛÚ À´×Ô ¹ã¶«ÉîÛÚ
ÏÖÔÚÏàÂ¥Ö÷ÕâÑùµÄºÃÈ˲»¶àÁË£¬Ð»Ð»Â¥Ö÷£¡
ÄúÐèÒªµÇ¼ºó²Å¿ÉÒÔ»ØÌû µÇ¼ | ×¢²á
±¾°æ»ý·Ö¹æÔò
¿ìËٻظ´ ·µ»Ø¶¥²¿ ·µ»ØÁбí
¸½½ü
µêÆÌ
΢ÐÅɨÂë²é¿´¸½½üµêÆÌ
άÐÞ
±¨¼Û
ɨÂë²é¿´ÊÖ»ú°æ±¨¼Û
ÐźÅÔª
¼þ²éѯ
µãλͼ
оƬËÑË÷
¿ìËٻظ´
