一、启动时,按Ctrl+B进入BOOTROM目录 华为交换机console密码忘了怎么办 图1 · 盒式交换机的某些款型支持运用快捷键“Ctrl+E”进入BootROM主菜单,请根据设备的界面提示操作。 · 盒式交换机在V100R006C03之前的版本,BootROM默认密码为huawei;在V100R006C03及其之后的版本,默认密码为Admin@huawei.com。 · 框式交换机在V100R006C03之前的版本,BootROM默认密码为9300;在V100R006C03及其之后的版本,默认密码为Admin@huawei.com。 三、输入7,清除console密码 华为交换机console密码忘了怎么办 图2 华为交换机console密码忘了怎么办 图3 无密码模式进入,修改console密码的方式 system-view Enter system view, return user view with Ctrl+Z. [hws2]user [hws2]user-interface con [hws2]user-interface console 0 [hws2-ui-console0]authentication-mode pa [hws2-ui-console0]authentication-mode password [hws2-ui-console0]set authentication password cipher Huawei@123 [hws2-ui-console0] 六、保存配置(一定要记得保存密码) save The current configuration will be written to the device. Are you sure to continue?[Y/N]y Jan 1 2008 00:26:03-05:13 hws2 %%01CFM/4/SAVE(l)[27]:The user chose Y when deciding whether to save the configuration to the device. Now saving the current configuration to the slot 0 . Info: Save the configuration successfully. |
